Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-25-2014, 11:40 PM   #1
swissarmychainsaw
Clean Slate what to do?
1973 Suburban, and I need tunes. Been years since I have...wait that's not true. I HAVE NEVER had a good stereo system in a car.
Closest I have come is my wife's stock Civic!
So it's time. I'm not looking to become a wizard at this, I would love to just buy a system and install it.
The truck is enough of a project without going down that rabbit hole. I am a total n00b at stereos and amps and stuff.
My Goal is to a have "new car quality" stereo system.
The doors are cut for speakers, and I'm either doing to replace the doors or use the holes for speakers.
Budget is $1,000 out the door. Going to be used as a camping rig (so a second battery will be installed).
What system would you build?
swissarmychainsaw is offline   Reply With Quote
Old 02-27-2014, 12:21 PM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Clean Slate what to do?
For that you can easily add a decent head unit, amp and 5 speakers.
I would go with an 8" sub, preferable mounted in the cargo area, component speakers in the doors, an amp with something in the general range of 4 x 40 rms + 1 x 150 rms and a head unit you like the looks of.
Generalizing cost:
head unit $150
amplifier $250
sub + enclosure $150
speakers $300
cables, hookups -n- sundry $100
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 02-28-2014, 03:31 PM   #3
Special-Ed
Special-Ed's Avatar
A g-note will not be enough to do it properly.
DIY getting everything from crutchfield you are going to be around 1400 bucks. And that will be with low end junk.
Your going to need speaker wire. Head unit, dash kit, amps, speakers, harness kit, power and ground cables, component interconnects, iPod or mp3 interconnect, sub and then any dynimat sound deadening products
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 02-28-2014, 07:14 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
A grand is doable for a "Clean" system, but you won't be setting DB or SPL records.
There are a few ways you can do this, so I'll pose them seperately.
1. BASIC
Buy a good HU with good power output (over 30w per channel)
Buy a single 10" sub in the 250-500w range
Buy a matching mono amp
Buy a pair of 2 or three ways for the doors (make the doors the "rear")
Buy a pair of small speaks for the dash (making them the front)
OR
Buy a speaker box/corner box and get speakers for a rear-fill. (thereby making the doors the "front", or by removing the doors and having the dash speakers and rear fill)
This is probably the cheapest way, and gives you better speakers, a better/cleaner sound source, and a sub. This will have the least real "power" in the speakers, but will still be much better than stock. You will also have good "boom", but may drown the high-end frequencies at highway speed between exhaust/wind/engine/and sub. The lack of amp'd power to the speakers is often the cause.
2. ENTRY LEVEL
Buy a decent HU, but focus on features you like and don't worry about the power it makes. Make sure it has 3 pairs RCA outputs. A unit with less can work but indicates a lower end unit not designed for "full" use.
Buy a pair of true Component speakers for "front" (doors or dash)
Buy a pair of decent 2 or 3 way speakers for a rear fill
Buy a single 8-10" sub
Buy a 3 channel amp OR a small (~100w) stereo amp and a mono amp for the sub.
In this way, you would run the components amp'd, and the regular speakers off of the HU. The 3 channl config would include the sub making the wiring simple, and not needing a second amp, but 3 channels aren't as common and sometimes are more expensive that 2 seperate amps. You get better audio from the components, but the NEED for an amp becomes apparent. Running components without an amp can sometimes sound worse than running a regular speaker the same way. You save $ by not buying expensive components an another amp (or larger amp) for the rear speakers, but lose power and sound quality. This is acceptable to some folks since the rears are fill-only, and the front components handle most of the SQ.
You can also do a variation of this by swapping the components and isntead running TWO pairs of good 2/3 way speakers, and pairing them off the stereo amp. This will lose F/R control, but will get 4 speakers amplified cheaply as long as the power and resistance divides out. This isn't ideal, but has been done.
3. INTERMEDIATE
Same as above, BUT
Buy TWO pairs of good 2 or 3 way speakers
Buy a 4 channel amp*
Buy a mono amp for sub*
*or buy a 5 channel amp
This retains L/R/F/R controls, and allows for full power to each piece. This is a pretty good "regular" way to add speakers and a sub. It delivers enough power to each speaker, will sound much clearer than non-amp'd speakers. 5 channel amps can be a bit expensive sometimes, but you can always get a good 4 channel and speakers, and add another amp and sub at a later time.
4. ADVANCED
Same as above, BUT
Replace one or both of the regular speaker pairs with Components (the real ones with external crossovers).
Increase the amp size to support the higher power ratings on the crossover speakers, and consider 2-amp method, seperating the sub to a mono block or its own stereo amp.
This will also allow you to do a better job sizing the sub-amp combo, since you can go MUCH bigger on a mono than on a 5 channel.
5. OPTIONAL
Two pairs of good components
Two stereo amps, one for each component pair
Mono block amp or Stereo amp
Single 10-12 sub or pair of subs
Get it all from a company like Alpine, and use their staging device for an attempt at sound staging your car.
This stuff is all pretty much costly and not gonna happen under $1k, but I wanted to illustrate some of the "tiers" of equipment.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-01-2014, 10:18 AM   #5
earl84
Dayum, BR3W CITY, that is a seriously good writeup. Might have to cut and paste that to my "ideas" document.
earl84 is offline   Reply With Quote
Old 03-01-2014, 11:52 AM   #6
swissarmychainsaw
Awesome, thanks a bunch! I'm going to do some "research" and I'll be back with questions!
Old 03-05-2014, 02:01 AM   #7
ca90ss
If your only goal is "new car quality" you can pick up a HU for $100-150, a decent pair of coax speakers or even a cheap set of component speakers for $100-150 and spend the other $700-800 on sound deadening.
ca90ss is offline   Reply With Quote
