Old 03-01-2014, 02:46 AM   #1
vortech71chevy
5 in drop rear- axle on bumpstops?
Hey guys, just bolted up some 5 inch drop springs in the rear of my 65 long bed... Set her down and the axle is on the bumpstops. Seems to me this should not be happening. The bed has two tires and an old radiator in it, so I dont think that's the issue. Does the 5 inch rear drop require bumpstop relocation and c notch usually? What else could be the problem? Thanks for any and all help.
vortech71chevy is offline   Reply With Quote
Old 03-03-2014, 02:36 AM   #2
sduckworth13
sduckworth13's Avatar
Re: 5 in drop rear- axle on bumpstops?
Change your shocks out first, that should help. Most people that do a 5 inch drop don't notch the frame.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-03-2014, 03:22 AM   #3
vortech71chevy
Shocks shouldn't be bearing any load though right?
Old 03-03-2014, 03:34 AM   #4
sduckworth13
Sounds right, I don't know what else you could change to fix it since you have changed out your springs.
Scott
Old 03-03-2014, 03:35 AM   #5
sduckworth13
post some pics up, one of the gurus can help you in the morning hopefully
Scott
Old 03-03-2014, 03:40 AM   #6
sduckworth13
here is a thread that talks about the same issue
http://67-72chevytrucks.com/vboard/s...d.php?t=250370
Scott
Old 03-03-2014, 03:44 AM   #7
sduckworth13
Here is one more thread
http://67-72chevytrucks.com/vboard/s...d.php?t=509074
Scott
Old 03-03-2014, 07:33 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You have to remove your bumpstops to regain some travel. Shocks have no bearing on this.
