Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-24-2014, 12:34 PM   #1
East Tex
Project 6 Point Oh
I've decided to start a build thread after working on my 72 K5 Blazer for almost two years. I was just going to get it drivable and not do a restoration, but I couldn't stop myself LOL. Now I'm in the process of a frame off restoration, and dropping in a 6.0 LQ9 and a 4L60. I don't get much time off from work, so the process is slow, but steady. I was a mechanic years ago and worked on tons of these old trucks, but I got out of the business way before LS motors were introduced, so I will be needing advice on that end. I've taken tons of pics along the way and will post a few. Three things I don't do are transmissions, and paint and body work. Everything else I plan on doing myself.
East Tex is offline   Reply With Quote
Old 03-24-2014, 12:50 PM   #2
East Tex
Re: Project 6 Point Oh
This is what it looked like when I went to buy it. Sitting outside with no top on, roll bar in backwards, wiring pulled out, no brakes, and barely running.
The truck looked good from a distance, but was really rough up close. The floor was toast but I couldn't tell because of a thick coat of fiberglass covering the damage. The gas door install was horrible and covered up by LOTS of bondo. The patch for the original gas neck hole was a thick layer of bondo too.
Old 03-24-2014, 12:52 PM   #3
East Tex
Old 03-24-2014, 12:56 PM   #4
East Tex
I think the only thing electrical that worked was the ignition switch and an external horn button. lol
Old 03-24-2014, 01:07 PM   #5
East Tex
Got the double wall top back on it and got it home. I don't think the top had been on it in a long time. It had been outside with no top, exposed to the elements for no telling how long.
Old 03-24-2014, 01:13 PM   #6
East Tex
Old 03-24-2014, 01:21 PM   #7
East Tex
Got the front clip off and the motor and trans out.
Old 03-24-2014, 01:25 PM   #8
East Tex
Found a 2003 6.0ltr out of an Escalade with 77K on it.
Old 03-24-2014, 01:31 PM   #9
East Tex
I could tell there was going to be issues lol.
Old 03-24-2014, 01:36 PM   #10
East Tex
Looks like it used to be white. The SPID was gone, so I wasn't sure.
Old 03-24-2014, 01:47 PM   #11
East Tex
Old 03-24-2014, 01:51 PM   #12
East Tex
Old 03-24-2014, 01:58 PM   #13
East Tex
The wiring had more butt connectors and electrical tape than I'd seen in a while.
Old 03-24-2014, 02:00 PM   #14
98Murray
98Murray's Avatar
Looks awesome!!
98Murray is offline   Reply With Quote
Old 03-24-2014, 02:02 PM   #15
jaros44sr
jaros44sr's Avatar
Vin plate match title? Ill watch
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-24-2014, 02:10 PM   #16
East Tex
LS motor mount from Pacific Fabrication, 4L60 to NP205 adapter from Advance adaptors, and a Ididit tilt steering column.
Old 03-24-2014, 02:12 PM   #17
East Tex
Yes VIN plate does match.
Old 03-24-2014, 02:16 PM   #18
East Tex
Oh boy
Old 03-24-2014, 02:20 PM   #19
East Tex
Rusted out inner fender and a bonus quart of oil!
Old 03-24-2014, 02:30 PM   #20
East Tex
puke
Old 03-24-2014, 02:34 PM   #21
East Tex
Old 03-24-2014, 02:39 PM   #22
East Tex
At least the rocker boxes underneath were good.
Old 03-24-2014, 02:57 PM   #23
East Tex
They had brazed a piece of metal behind the original gas neck hole, then filled the rest with bondo!!!
It looked like a hockey puck went in there.
Old 03-24-2014, 03:03 PM   #24
East Tex
Old 03-24-2014, 03:08 PM   #25
East Tex
That's gonna have to be replaced and redone correctly. So far this truck needs everything.
