Old 03-26-2014, 09:32 PM   #1
ckhd
ckhd's Avatar
Problem w 92 K1500 4 wheel drive
92 k1500 'burb 170k miles, just bought it.
Wouldn't go in to 4 wheel drive. T-case shifts fine, after a few seconds, the diagram on the floor would light up, but if I got in a tight spot, only the rear tire(s) would spin, and it sounded like when you use your drill to screw in a screw, but strip the head... Kind of a buzzing sound, but slower and with more mass. Normally driving a 68, 69, or 72 -all with manual hubs and gear t-cases, I thought it was the actuator. After all, everyone complains about the thermal actuator.
I replaced the actuator. It still does the exact same thing. What are the chances of the problem being in the transfer case?
I think it's a NP 241.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 03-26-2014, 10:20 PM   #2
Campbel45
Re: Problem w 92 K1500 4 wheel drive
I believe there is a fuse going to that actuator. May make sure you are getting good power and ground to that. The actuator has a heating element that takes time to heat and then finally shift. Should take a maximum of 30 sec. though
Campbel45 is offline   Reply With Quote
Old 03-27-2014, 07:28 AM   #3
ryanroo
ryanroo's Avatar
there are some little pads on the shift forks inside the case that isolate the fork from the collar. its possible that they have work out and are not letting the case fully engage. that could give you the noise and lack of front engagement as well.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 09-20-2015, 11:58 PM   #4
ckhd
ckhd's Avatar
Pardon me while I dig up this old thread. I found out what was really wrong and didn't post the answer...
It was the outer right CV joint. The only thing holding it together was the rubber boot, and when torque was applied, the cv joint would slip on the inside. That's where the noise was coming from.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
