Old 04-09-2014, 12:18 PM   #1
Nitis
Nitis's Avatar
LS swap in a 72 4x4
Kind of a repeat post so I apologize
What issues or difficulties will be encountered doing an LS swap in a 72 4x4?
Also any reason not to just mate the engine to a 700r4?
Nitis is offline   Reply With Quote
Old 04-11-2014, 10:31 AM   #2
Nitis
Nitis's Avatar
Re: LS swap in a 72 4x4
Been following this thread a little
http://67-72chevytrucks.com/vboard/s...d.php?t=608879
Old 04-27-2014, 05:31 PM   #3
K10 STEPSIDE
K10 STEPSIDE's Avatar
I am just finishing up a 5.3 LM7 swap in to my 67 K10.
first you will have all the typical things to change: fuel pump and lines, wiring, exhaust, engine mounts, temp and oil sensors, throttle linkage/cable or electronic pedal, radiator hoses.
But, specifically for the four wheel drive it is difficult to fit the engine without a lift kit. I would say it is possible with some custom work to move the engine higher in the frame.
I myself use a manual transmission so I'm not one to know about the automatic questions, but I would guest it should be easier to use the 700.
Do you have any specific engine in mind?
What transmission and transfer case do you plan on using?
Do you plan to lift the truck for the swap?
Is you gas tank still in the cab?
All these questions will help hammer down your project specifics.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 04-27-2014, 06:13 PM   #4
Nitis
Nitis's Avatar
I do plan on using a blazer/suburban style tank in the frame in the rear
I plan ton use the existing no205
I would like to purchase a complete engine tranny together so probably 5.3 4l60e unless I can come upon a deal for a 6.0
I would do maybe a 2.5 lift but no more than that
Found dirty dingo makes a crossmember that helps fit the block. But still may need lift to clear oil pan?
With the new crossmember would I still need to switch to the trailblazer SS exhaust manifolds?
Old 05-05-2014, 03:25 PM   #5
K10 STEPSIDE
Sorry for leaving you hanging.
seams like you know what there is to know. as far as clearance.
If you build your own cross member and mounts I would say you can fit with out a lift as long as you keep it in mind as you build and keep things as high as possible. If you do lift the truck 2.5 will be enough for clearance, but for safety the bump stops should be lowered.
as far as the the manifolds. I used truck manifolds and they fit if you are comfortable with cutting but no matter the application I think they would not to be cut. These are my truck manifolds ceramic coated with the heat shields off the the extra bosses cut off.
as you can see I had to take a small circle out of the frame. Here is a few pictures of my mounts and clearance before a lift.
I think I could raise the engine enough if I redid my mounts that I could clear with a low profile oil pan and no lift. but my drive train angle with the married transfer would be pretty steep.
1967 chevy K10 step
2002 chevy Impala
Old 05-06-2014, 04:13 AM   #6
jamesjones
Freakin Awesome!
jamesjones's Avatar
TBSS or LS3 Camaro manifolds should fit with no cutting.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 05-06-2014, 04:39 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
I have a 72 K5 Blazer but it already had a 4" lift when I got it. I built my own motor mounts and used LS3 Camaro exhaust manifolds....
Use the 4L60e (or 4L80e) because the factory computer is already set to control it. 700R4 requires a TV cable that the LSx motor doesnt provide.
Rich
1972 K5 Blazer CST Click HERE
Old 05-06-2014, 10:11 PM   #8
71chevystep4x4
71chevystep4x4's Avatar
I modified the stock crossmember to fit, which the most modification was to the mount perches, then put in a set of Hooker block hugger shorties that are center dump. Main issue I ran into was it had a straight six originally, so even though a small block, and big block fit fine after it, I still had to move the crossemember and tranny and t-case forward 2" to fit the 5.3L
71chevystep4x4 is offline   Reply With Quote
Old 05-06-2014, 10:27 PM   #9
Bigdav160
Bigdav160's Avatar
No interference with the front crossmember?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-06-2014, 11:09 PM   #10
71chevystep4x4
yes, I had to square up the P/S corner of the crossmember where the oil pan rested on it. I would have liked to have gone with a special crossmember built for this purpose, but was on a budget, and happened to have a welder.
Old 05-08-2014, 08:33 AM   #11
Bigdav160
Bigdav160's Avatar
I was talking about the very front one. Where K10's P valve is mounted.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 05-15-2014, 10:29 PM   #12
K10 STEPSIDE
No, there was plenty of room there
1967 chevy K10 step
2002 chevy Impala
