Old 04-11-2014, 07:10 PM   #1
dman1982
dman1982's Avatar
tranny question?
when i put my motor and tranny in, lost a lot of tranny fluid, i went to move it and wouldn't move, so checked it the dipstick read like none, so i went and put some in, barely read, ended up having to put almost a gallon in it, now its starting to read, how much tranny fluid will this thing hold??? i assume that the tq converter drained some??? i know its kinda a dumb question but when i put this thing in i lost ALOT of fluid
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-11-2014, 07:31 PM   #2
PGSigns
PGSigns's Avatar
Re: tranny question?
They hold like 10 so keep adding till its happy.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-11-2014, 07:32 PM   #3
dman1982
dman1982's Avatar
11 lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 07:50 PM   #4
PGSigns
PGSigns's Avatar
Well you have added about 4 quarts so looks like you still have 7 to go. That should get it on the stick. I had to put close to 6 in mine.
Jimmy
Thanks for your service
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-11-2014, 07:54 PM   #5
dman1982
dman1982's Avatar
Now I think I got one quart too many...err! How do I get it out without dropping the pan?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 07:55 PM   #6
dman1982
dman1982's Avatar
And your welcome haha
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 07:57 PM   #7
PGSigns
PGSigns's Avatar
Pull the dip stick tube out of it.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-11-2014, 07:58 PM   #8
dman1982
dman1982's Avatar
That easy? Holy cow
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 08:17 PM   #9
PGSigns
PGSigns's Avatar
I have done it for other reasons and had it make a big mess so I know it will lower the fluid level.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-11-2014, 08:27 PM   #10
dman1982
dman1982's Avatar
another random question, i pulled my truck out and took it around the block for another test run after i filled the fluid and hooked up the tcc, shifts kinda weird, if i hook the tranny lines up wrong will it still move?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 08:29 PM   #11
dman1982
dman1982's Avatar
could it be because I'm running open manifolds right now? maybe its not shifting weird its just so freakin loud i can't tell
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 08:36 PM   #12
PGSigns
PGSigns's Avatar
Until it is all done and setup its hard to tell what they are doing.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-11-2014, 08:57 PM   #13
dman1982
dman1982's Avatar
That's what I was thinking, but it's sooo loud hard to tell what it's doing
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 08:57 PM   #14
dman1982
dman1982's Avatar
But if the tranny lines are in backwards will it still move and shift?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 08:57 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Did u fill the convertor first, separately?
As for taking some out, my 80e has a drain plug thats a huge torx, like a T50.
Shifting might feel weird for a couple reasons. With open headers, its possible your getting way out of wack 02 trims, and it might pull a bunch of timing (so everything feels weird). Also, shift firmness, tq management in the tune can affect the feel...so if you haven't done a road tune or at least acclimated to the feel, it can feel off.
The first few days on my 4l80e were weird, since it was a fresh rebuild, fresh converter, and the fluid was about 40*. Once we had that figured out, we realized there was an issue with false knock causing lockup problems (weird shifting issue #2)
On the free-n-easy side, check the connections at the side of the trans and make sure they don't have any fluid on them etc, and that they are fully plugged in with a clean connections. Its also a good idea to double check wiring and lines/piping once you've had it warmed up a bit. Sometimes vibrations and heat can move,sag,melt, or pinch wiring that looked good when it was static.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-11-2014, 09:01 PM   #16
dman1982
dman1982's Avatar
Good thinking, going to try and get the exaust put on tomorrow, I'm going to through the connectors and stuff here in a moment...as far as the tq converter the engine and tranny went in together, never unbolted them
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 09:27 PM   #17
dman1982
dman1982's Avatar
and another random question (didnt want to make a new thread) but the rubber hoses that come out the back of the trans, what are those for? do they need to be hooked up to anything??
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 09:38 PM   #18
dman1982
dman1982's Avatar
and that electrical connector on the drivers side, i need to put that on the correct way...how the heck do you do it??? I've been searching youtube and found nothing
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 10:13 PM   #19
desertdogg
desertdogg's Avatar
Are you talking about the big one that goes on the black shifter module ? I just took off my harness and I thought it could go in only one way.
Trying to get thru my LS swap
desertdogg is offline   Reply With Quote
Old 04-11-2014, 10:14 PM   #20
dman1982
dman1982's Avatar
thats the one man, but it has a locking mechanism in it and can't figure it out, i was told how to do it but its not going all the way in
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 11:01 PM   #21
dman1982
dman1982's Avatar
i just figured it out so stoked!!!
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-11-2014, 11:34 PM   #22
desertdogg
desertdogg's Avatar
Old 04-12-2014, 01:47 AM   #23
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
[QUOTE=dman1982;6624721]and another random question (didnt want to make a new thread) but the rubber hoses that come out the back of the trans, what are those for? do they need to be hooked up to anything??
I always forget, are you 60e or 80e? If its just the one rubber hose off a nipple towards the top of the case, its just a puke-hose for moisture.
Old 04-12-2014, 01:49 AM   #24
dman1982
dman1982's Avatar
I got the 60, and there is two
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-15-2014, 09:15 AM   #25
smartass12
smartass12's Avatar
How did you do it? i can only get mine half way in as well
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
