#16876
Best battery charger?
It's time to replace my old Century charger. I'd like 6/12v , 2-10-50 with Marine, AGM & Gel charging capabilities. Not sure whats out there these days, does this contraption exist?
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Re: Best battery charger?
Check Interstate Batteries, Grainger or Pacific Batteries. That if there is any supply warehouses down there.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
motor exploder
I got one of these: http://www.batterychargers.com/Produ...tName=94026976 from my local Interstate Batteries store. They recommended it as Schumacher's top notch charger. It's the XC103. I was suprised at how compact it was for the power it has.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Didn't you work at a battery place?
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#16876
Ya but they did not make/sell chargers. I'd never buy from them bee-stards again. Good products, maybe even the best but the guy I worked for was a horrible person.
#6 | |
#16876
I see. Bee-stards huh? Sounds like you got stung a few times.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I see what you did there. Very punny.
Your welcome. I'll be here all week...
meowMEOWmeowMEOW
Be careful when hunting for one. I had an Optima die prematurely on me one year, and I couldn't figure out WHY. It had been on an "onboard" maintenance charger from NAPA, which had always worked just fine before.
Then I found out that Optima wants a 1 AMP charge, which is extremely low. Most "snap" chargers are 2,5,10a and many maintenance chargers are 1.5-5a....which made it pretty annoying knowing a 1a was the recommended size. I just stopped using the maintenance charger on the optima. Instead, I make sure the truck runs long enough on its "last voyage" for the year to get a full charge, then I disconnect it and keep it up off the floor. If you watch my Startup Video on my channel, it fires over first try with an Optima Blue that sat for about 6 months.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Sep 2005
sitting on the floor has no effect on them any more my redtop sat on the floor for over 8 months and she started right up.
but i have one of these for my normal batterys and a small2 amp for my optimas
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
i've had a battery charger that i got from sears a reasonable price and it's goin on 25years old without a problem
#13 |
Pretty sure I have an extra you can have till you get one you want.
Not so sure you didn't give it to me few years back? Also have that Interstate connection if needed.
"I feel the need for speed!"... as soon as I am done with my nap. |
#14 |
#16876
No need now. I took apart the old one and made an obvious fix after I dropped it. I may still look for a AGM/Marine/Wet cell charger though.
#15 | |
meowMEOWmeowMEOW
You live in a MUCH warmer climate. Since Optima/AGM batteries are still lead-acid, the chemical reacting is still vulnerable to temperature, slowing the galvanic reaction. When you put a battery on the floor, the concrete become an area of low heat load, while comparatively the battery is "warm". The floor will draw any remaining warmth from the battery, slowing the reaction further. IF you were to try and start something off of that battery, it would probably be dead. HOWEVER, if you let that same battery come back up to a more stable temperature, it may function again like normal...since the heat load is allowed to stay around the battery. There is no Temperature known as cold, cold is only the absence of heat load.
#16 |
10/30/19
3 shows nightly and don't forget to tip your waitress.
Fight the good fight, finish the race, keep the faith |
