Old 04-15-2014, 08:05 PM   #1
1963chevyc20
1963chevyc20's Avatar
What the heck was that!!!
It all started when I. Decided to go for my old 63 c20. I took a 20 mile trip to town. I picked up my newly purchased AR-15 and headed home. As I was pulling into the drive I decided to try something I.had bot done before and wanted to do. I would do a perlite in reverse! I revved the engine up, fixed that clutch let it out to take off and POP! Truck died. I started it back up and was just going to park it. I taped the gas and nothing happened. It didn't move! Oh. It was in neutral? Ok. Shifted to reverse to back it in to the barn and taped the gas while letting out the clutch. Vroooom! That's all that occurrd. At that time my sister ran out and said "something just Dell out from under you're truck!". Worried I jumped out to see a large puddle of oil and reverse laying in the dirt! Now my original 3 on the tree is no more! I am VERRY upset! It still runs and drives in 1st 2nd and3rd. Can I fix it?
1963chevyc20 is offline   Reply With Quote
Old 04-15-2014, 08:08 PM   #2
1963chevyc20
Re: What the heck was that!!!
perlite. Mention to say peal!
Old 04-15-2014, 08:21 PM   #3
71swb4x4
71swb4x4's Avatar
Find another three speed, most people have to give them away, so you should be able to find one pretty cheap.
Next time you go to peel out remember you have a 50 year old truck, you will find the weakest link.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-15-2014, 08:27 PM   #4
66Submarine
66Submarine's Avatar
Not a great idea, as you learned. Reverse isn't intended to see a lot of abuse (or any, really) and isn't real strong. If there's stuff on the ground I'd say that trans is probably only good for whatever spare parts aren't broken. You'll obviously need a new case, and as cheap and (relatively) plentiful as these are, I'd say your best bet is to just find another good one for $50-100 and plug it in there. I don't think trying to repair the broken case would be a good idea.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 04-15-2014, 08:28 PM   #5
HumphreyMurdoch
HumphreyMurdoch's Avatar
Too bad you aren't closer, I've got 2 in my basement you can have!
HumphreyMurdoch is offline   Reply With Quote
Old 04-15-2014, 09:42 PM   #6
Slow Build
Slow Build's Avatar
If it's revving without much pedal input you might want to check the motor mounts.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-15-2014, 11:36 PM   #7
1963chevyc20
Is there any possabyle way you can see if you can shp to me? My stupidnss was not at good timing. That is my only running truck. Have a 71 camaro. Motor in in peaces in box tho.
Old 04-15-2014, 11:39 PM   #8
1963chevyc20
Moter mounts fine. It does not rxcelarate like you are thinking.
Old 04-15-2014, 11:42 PM   #9
1963chevyc20
Would it de fine to drive until I get a new trans?
Old 04-16-2014, 06:44 AM   #10
PGSigns
PGSigns's Avatar
It is just going to loose all the oil and shread itself into more pieces. I would get looking today.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-16-2014, 09:35 AM   #11
Bears63
...just another truck junkie..
Bears63's Avatar
The last three 3-speed trannsmissions I had went to the scrapyard. I couldn't give the things away. Look for about an hour in any town in this country and you will find one somewhere.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 04-16-2014, 09:49 AM   #12
Old Truck Man
Old Truck Man's Avatar
Reverse is very weak in the early Muncie three speeds. You cant drive it because you dong have any trans oil. Now if Ya could find the broken pieces and stick then back with JB Weld you could refill it with 90 weight. You michr check at your local scrapper recycler. they may have a trans. Actually I like the early three speeds they have a lower first gear than the later Saginaw trans.
Old Truck Man is offline   Reply With Quote
Old 04-16-2014, 09:53 AM   #13
Old Truck Man
Ok now I see that your truck is a C20. I would look for a granny four speed it will make hauling & towing much better.
Old 04-16-2014, 11:23 AM   #14
1963chevyc20
Maybe onday. But my truck was all original. I will just put it 3 on the tree again
Old 04-16-2014, 11:44 AM   #15
1963chevyc20
And can any one show picks or a vidieo on how to remone my trans and hot to hook up a 3 on the tree? Don't know how!!
Old 04-22-2014, 10:06 AM   #16
Kyle@FTP
1963chevyc20 I have a 3spd for you. Just pay shipping and its all yours.
Also, empty your PM box.
Kyle@FTP is offline   Reply With Quote
Old 04-22-2014, 12:26 PM   #17
Mathew21
Mathew21's Avatar
That's really cool of you.
Mathew21 is offline   Reply With Quote
Old 04-22-2014, 04:12 PM   #18
sick boy
sick boy's Avatar
Nice. Thats what its all about. Members helping members
sick boy is offline   Reply With Quote
Old 04-24-2014, 12:27 PM   #19
1963chevyc20
thanks everyone!!! it really helped as this was an un expected expennce!
Old 05-16-2014, 10:03 AM   #20
1963chevyc20
here is the damage
Old 05-16-2014, 10:06 AM   #21
1963c-10
1963c-10's Avatar
Yeah, you'll need a new main case....better just look for another trans.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-16-2014, 10:12 AM   #22
1963chevyc20
that is what i am going to do
283 v8, help!, tranny
