04-19-2014, 09:55 PM | #1 |
Lower Radiator Hose...ARRRGGHH
I am rebuilding my truck which can be seen at the link below. I have a new 350SBC Crate motor with a long style water pump. I am using a 4 core radiator and have purchased all regular brackets, hardware etc. Upper hose, no issue. Lower hose has been a pain. I went a purchased a hose for a 71 Chevy truck and it wont fit. After going to some cruise this spring I have discovered that a "stock "radiator lower neck comes out and up at an angle and the radiator I have comes straight out. I am sure, or at least I hope that I am not the only one to have encountered this problem. Any ideal part number, ideas, or whatever would be great, short of telling me to purchase a new radiator.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
04-19-2014, 10:12 PM | #2 |
Re: Lower Radiator Hose...ARRRGGHH
Yep, it's a wicked bend. It will fit, you'll probably have to cut off several inches to get it to the right length.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-19-2014, 11:07 PM | #3 |
You can take it to your local rad shop and have him shorten it and braze or solder an elbow onto it. Shouldn't cost that much.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
04-20-2014, 12:13 AM | #4 |
Sorry I don't have a pic, but I recently went through the same issues with my ZZ4. I finally found a bottom hose that would work. Try a AC 24053L. If I can remember to take a pic tomorrow I'll post a pic.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
04-20-2014, 09:24 PM | #5 |
Here you go.
04-21-2014, 05:36 AM | #6 |
Just ordered 24053L from Rock auto online. They have a close out on them. $13.50 shipped. I had the same problem with mine. I ended up having to cut the hose I had and use pipe in between. I hope this one works.
04-21-2014, 07:46 AM | #7 |
That looks like exactly what I need. I like how it rolls over the frame versus the stock one laying on the fram rail. I will try that one. Thanks a bunch.
I will let you all know how it works out.
04-21-2014, 08:56 AM | #8 |
Could always stick a piece of an old hose under the new hose on the frame to keep it from rubbing. A short piece of pipe wont hurt either. Some trucks came from the factory this way.
04-21-2014, 10:02 AM | #9 |
Glad I could help. You'll notice I did use some plastic corrugated pipe over the hose to protect it from rubbing on the frame. Hope it works for you guys.
04-21-2014, 10:40 AM | #10 |
I am guessing here... But I think that is a 73-newer Radiator.
If my memory is correct... They are the same dimensions but the lower hose connection is the difference.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
04-21-2014, 10:58 AM | #11 | |
I like the idea of having the rad shop ad an elbow to it. This might be a good solution also.
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
04-21-2014, 12:55 PM | #12 |
I think you maybe correct. I just can't remember.
04-28-2014, 08:34 AM | #13 |
Got the AC24053L off Ebay for 13 bucks. Did some small trimming and it fit perfectly. Thanks for the suggestion.
04-28-2014, 09:46 AM | #14 |
Glad it worked out for you.
07-31-2014, 08:00 AM | #15 |
so its normal for the stock hose to be touching the frame? I dont like it. Im going to try the one above as well. I have a new alum rad but its the same as my old rad. mine has no up angle on the lower outlet.
07-31-2014, 09:05 AM | #16 |
I know this thread is a few months old but I searched Rock Auto, Napa, autozone, advance auto, and O'reilly auto parts for AC 24053L and no one had it. Any other suggestions where to get this hose? Thanks.
Nevermind...I found one. Last edited by Steve Cole; 07-31-2014 at 09:13 AM. Reason: Found it. |
07-31-2014, 11:55 AM | #17 | |
Goodyear 60855
07-31-2014, 03:28 PM | #18 |
08-01-2014, 12:04 PM | #19 |
Yes, direct interchange from both respective websites.
It is simply the replacement lower hose for a 1973-1983 Chevy/GMC C10/C20/C30 2wd 350cid application .
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 08-01-2014 at 12:13 PM. |
08-01-2014, 03:40 PM | #20 |
Good to know, thanks!
01-21-2016, 09:45 PM | #21 |
I also came to that later year hose as the best option. My engine sits 6" farther back and 1" lower, so I had to weld a longer outlet angled up to my aluminum rad. No rubbing anywhere.
Russ
RC |
01-21-2016, 10:35 PM | #22 |
The stock factory radiators for these trucks have the lower radiator hose connection angled so the lower hose will lay right on the frame rail. Stock 4 core radiators are hard to find I think they only came on trucks that had a big block and air conditioning.
Ugly 61 |
01-24-2016, 05:46 AM | #23 |
I have an older 4 core radiator, don't know if its original, but its brass and it does have an angled neck. I bought the original radiator hose it lays directly above the frame rail and doesn't touch.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
01-24-2016, 08:24 AM | #24 |
I am having issues with this also.I tried the Gates 20843 and the water pump end is too small and will not slip on.
01-24-2016, 11:56 AM | #25 | |
I'm using the gates 20694 and it works perfectly.. When it's out of the truck it doesn't look like it will work but it does.. A local mechanic who restores 67-72 c-10's helped out when he saw I was running 2 hoses and a metal piece as my lower hose |
