04-20-2014, 11:20 AM | #1 |
bbw /c-60 question
i located a 66 gmc -c-60 with the big back window ! does anybody know if the complet cab backside is the same as a 1/2-3/4 ton truck ? looks same ? maybe cab mounts are differant ?
04-20-2014, 11:57 AM | #2 |
The 60-66 GMC/Pontiac guy....
Re: bbw /c-60 question
In general, it's the same cab.
Dash is different and cab mounts are convertible, (can be converted) It is 100% easier to "re-cab", changing the dash and fitting the cab to a 1/2 ton frame than it is to do a BBW conversion. Just saying
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
04-20-2014, 12:58 PM | #3 |
60-66 Nut
Yes the cabs are basically the same with a few differences. The biggest difference is the lack of a trans tunnel/hump in the floor. As 66-PMD-GMC said, you could use the whole cab, as long as it is not a LCF cab
04-21-2014, 12:19 AM | #4 |
Hollister, CA.
Your in the wrong area, btw ....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
04-28-2014, 10:34 PM | #5 |
chris apache -junction -NO its easier to do the window change ! the roof had something big dropped on it ! just seen the truck, thought the price might be right for a bb window conversion
04-29-2014, 12:52 AM | #6 |
Most of the BBW conversions I have seen look OK but ....
IMHO.... to do it correctly the roof skin should be pulled so that the top seam can be welded right. Of course I have only done this conversion a couple dozen times so I'm still learning. ;-) Then again, you have your eyes on the job so you would know best.... Good luck on your job!
