Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-05-2014, 04:01 PM   #1
pwdcougar
pwdcougar's Avatar
Garage door spring safety cables
Wondered how many guys are trusting the safety cables that run through overhead garage door springs. My doors are old heavy wooden ones with pretty heavy duty springs. One of the springs let go the other day and tore apart the safety cable I got from either Home Depot or Lowes. This was a pretty good diameter steel cable too. The cable just snapped in half!
Luckily it didn't do any damage to my car.
I'm going to get 3/16 or 1/4 inch cable and re do them.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 05-05-2014, 07:20 PM   #2
truckdude239
truckdude239's Avatar
Re: Garage door spring safety cables
i had the coil spring on my shop doors break at work total pain in the butt as the door take 3-4 people to lift when teh springs quit. they saound likea bomb going off but thankfuly they have a steel rod though tehm
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-06-2014, 09:49 AM   #3
racecougar
racecougar's Avatar
They certainly do. I had one let go last year...I think my ears are still ringing.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 05-06-2014, 10:31 AM   #4
pwdcougar
pwdcougar's Avatar
A steel rod welded at each end would be a heck of a lot safer than the cable. I'll probably go with 1/4 inch cable though. When I was a kid one went out and it put a hole in the sheet rock and a huge dent in the 2 X 4 stud underneath it. If it had hit someone it would have killed them!
Paul
Old 05-06-2014, 11:34 AM   #5
racecougar
racecougar's Avatar
Originally Posted by pwdcougar View Post
A steel rod welded at each end would be a heck of a lot safer than the cable. I'll probably go with 1/4 inch cable though,
Well yeah, a steel rod won't work too well with the extension type door springs. The spring pictured above is a torsion type door spring.
Old 05-06-2014, 01:33 PM   #6
pwdcougar
pwdcougar's Avatar
I'm pretty sure it could be rigged up with steel rod running through the spring and welded directly to the door track. It would only be 1/4" diameter and it may have a bend or two to clear the pulley on the end of the spring. It would be a bi*ch to change the spring though.
Paul
Old 05-06-2014, 01:48 PM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Neighbors spring broke recently, when the garage door tech came over to replace it he noted that the spring had never been lubed??? he said to spray the springs occasionally to keep them lubricated, extends the life of the spring, spray mine with WD40 every couple of months
Malo83 is offline   Reply With Quote
Old 05-06-2014, 02:48 PM   #8
pwdcougar
pwdcougar's Avatar
Really??? On the long stretchy springs? Guess I'll have to try that!
Paul
Old 05-06-2014, 02:52 PM   #9
racecougar
racecougar's Avatar
No, it's the torsion type springs that should be lubricated.
Old 05-06-2014, 03:05 PM   #10
ERASER5
ERASER5's Avatar
Yep. It's no-go on a solid rod. The extension springs move around quite alot. Replacing those springs is a real enjoyable job too.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-06-2014, 05:36 PM   #11
MadManAndrew
We recently had that happen to our overhead garage door. It did sound absolutely horrendous. What was odd was that the door was is only like five or six years old. The tech said a similar thing to what was said above about the springs and the hinges, etc never having been lubricated. He put bigger springs on and lubed everything and the damn door is almost silent now besides the faint little hum of the opener motor. Before you could hear it opening from the opposite side of the house.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 05-07-2014, 01:59 PM   #12
_Ogre
_Ogre's Avatar
the cable may have snapped but it absorbed a lot of the spring energy before it snapped
note to self: install cables that are laying on the shelf (for 5 yrs)
shop air compressor timer
