Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 05-06-2014, 06:04 PM   #1
biohazardbill
63-66 rear bumper
I have read that the rear bumpers are the same as the front bumpers. Some say though that they are upside down on the rear. Can anyone confirm this?
biohazardbill is offline   Reply With Quote
Old 05-06-2014, 06:18 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 63-66 rear bumper
Nope, they are not. Holes are in different places. They are close but not enough to use the correct brackets to hold everything.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-06-2014, 06:44 PM   #3
biohazardbill
Same basic shape though right? I can drill and fill holes.
Old 05-06-2014, 08:22 PM   #4
chakah
chakah's Avatar
this is on my Panel, you can compare yourself
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 05-06-2014, 08:48 PM   #5
biohazardbill
Thanks Chakah, looks like the same bumper but on the front they actually drilled out the indents.
Old 05-06-2014, 09:10 PM   #6
chakah
chakah's Avatar
Well, like chevy_mike said, won't bolt right up. The indents would be the front, you're right, but you'd have to drill and weld some holes. The frame widens in the back which makes 4 holes out of place. The two outer bolts measured the same distance apart.
"El Jerry"
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
Old 05-06-2014, 09:19 PM   #7
biohazardbill
Would you take a measurement as to how much the top of the bumper is above the rear valance?
Old 05-06-2014, 09:40 PM   #8
chakah
chakah's Avatar
here you go, 'bout 1 inch
"El Jerry"
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
Old 05-06-2014, 10:00 PM   #9
biohazardbill
Awesome, thanks so much.
