jack stand dolly
knocked one of these together last week. Need to paint it electric orange so I dont go sliding across the shop.
damn casters aint cheap. They should hold 1200 lbs per stand. assuming my welds hold ![]() ![]() ![]() the next 3 I'm going to move the wheels out more and trim off the part of the plate that will then stick out. Im not to worried about it but Id like a slightly wider wheelbase. home depot casters where about $6 each x16. 2 4' angle iron and 2 4' square stock. Cost around $150 total. Should support over 4000lbs which willmove any car i have around the show without to much trouble. |
Re: jack stand dolly
Not a bad idea but would buying them at harbor freight be about the same price without the work?
http://www.harborfreight.com/2-piece...ies-67511.html
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
well yea but those dont work so well when you have no wheels and tires
Good point!
heres my previous incarnation: they creak and groan with the rear end so I knew I needed something better for the frame buildup and future use.
2WD Jimmy
![]() Join Date: Mar 2005
Be Very Very careful. Looks like a potential tip hazard to me. Just dont want to see you injured.
Yea me either. The next 3 I build im going to put the wheels more outboard.
pffft. well i can admit to being wrong... I now see why nobody sells jack stand dollys. Lawsuit waiting to happen.
I made 3 more with the wheels more outboard but the stand the same size as the jack stand base. ![]() even like this I had one tip over under my frame when pushing it around when the wheel caught on a piece of trash. The only way I think to make this work would be to weld the jack stand to the dolly and make the dolly 2sqft at least. next time... |
![]() Join Date: Jul 2010
The thought is in the right place. I saw this product on Jay Leno's garage youtube channel. Pricey, but maybe you can reverse engineer it.
http://www.ezvjack.com/
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
