05-20-2014, 09:50 PM | #1 |
SunSoaked is back & the NV4500 Swap resumes
Hey guys,
14 months later, I find myself in a new job and itching to get back at my 69K10/CUCV project. I was able to marry up the NV4500 and NP205 during the down-time. Modified the shift rails for a twin-stick setup. Here's how she looks today; ready to drop in. I see several NV4500 conversion threads on here while I was away... Hope this helps somebody- BTW-I'm in need of a 32 spline fixed yoke for the rear output. Anyone? It's good to be back Last edited by SunSoaked; 05-20-2014 at 10:04 PM. |
05-20-2014, 10:30 PM | #2 | |
Re: SunSoaked is back & the NV4500 Swap resumes
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
05-21-2014, 01:40 AM | #3 |
that is nice! sure would like to replace the t400 with one
05-21-2014, 05:56 AM | #4 |
Is the adapter part of the NV4500. what year T-case are you using. I would like to do the same thing in my 71. I have the SM465 and 205.
05-21-2014, 07:52 AM | #5 |
The adapter is from AA and the 205 is a late "round 6 bolt" pattern built from new "old stock" parts, including the case.
05-21-2014, 09:13 PM | #6 |
are your shift rail detent pin plugs and the shift for roll pin access plugs threaded? was that a modification? i have never seen that before.
05-21-2014, 10:04 PM | #7 |
Yes, they are. I started with a new case, so why not? Easy enough to tap the holes and insert a 1/8" pipe plug. Won't have to deal with knocking out those itty bitty brass plugs and fishing them out of the case if I ever need to get into it.
05-21-2014, 10:12 PM | #8 |
I think its a sweet plan. FYI, at some point in the 80s, the brass core plugs were replaced by little rubber plugs that are much easier to deal with.
05-23-2014, 02:50 PM | #9 |
Good to see you getting back to the project
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
