Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-27-2014, 12:48 AM   #1
87Skier
87Skier's Avatar
Tires cracking
My Jimmy came with tires, but I'm not sure they are good for driving. I was hoping to keep the tires on and pretty much burn them off, and invest in new tires after the engine and transmission get figured out.
There is some cracking between the treads and very little on the sidewall. I can't find a date on the tires, but I think they are 17 or 18 years old.
What do you guys think? don't drive on them? use them for a month or two? just keep them?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 05-27-2014, 01:13 AM   #2
imjeff
imjeff's Avatar
Re: Tires cracking
I've got some old tires as well. Most of the current research says 6 to 10 years if they are properly maintained. There is no way to detect when the tire will come apart. I had a valve stem fixed last week and they told me the date code read 12 years old. They are my moving around while rebuilding tire, so they won't see the road. I did a little research and quickly found fatalities related to old tires coming apart. I'd replace them.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 05-27-2014, 01:53 AM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Tires cracking
Jeff is correct. Those tires should not be used on the street.
This was discussed in the tool forum a couple of years back.
If you follow the thread down you can see how the dates,
manufacturer codes, etc. are all on the back of your tires.
Tires past their safe age
Moving thread to Tools, Shops and Shop Safety forum.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 05-27-2014, 03:27 AM   #4
87Skier
87Skier's Avatar
Re: Tires cracking
Good to know, they will be replaced. I want to get bigger tires anyway and may consider killing the tires if you know what I mean.
