Old 05-28-2014, 08:54 PM   #1
angertheloner
angertheloner's Avatar
85 SM465 Transmission swap question
I am looking to swap out the transmission on my 85 C20 2WD from a SM465 manual to a better highway manual. I know you guys know these trucks. What would mate up to the 5.7L SBC 350 with more highway gears? Any suggestions?
What transmissions were available for NON-hydraulic clutches for the 350? Possibly one off a malibu, el camino, C10, or other? PLEASE HELP.
There are 10 kinds of people in the world: those who understand binary and those who don't.
1985 C20 Scottsdale 350/SM465
1978 C10 Silverado Big 10 3 on the Tree (sold)
angertheloner is offline   Reply With Quote
Old 05-28-2014, 09:31 PM   #2
TwoFiftyShifter
Re: 85 SM465 Transmission swap question
They made a 4 speed stick shift that had overdrive. A833? Anyway it is pretty uncommon.
Not sure if that came without a hydro clutch.
NV3500 is a good bet. Only came Hydro clutch though.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 05-28-2014, 11:26 PM   #3
Rubble
I have the A833 in an 82 K25. It's a mechanical linkage on it.Like was posted above,bit more rare but a nice little tranny.They were available as a hydraulic clutch as well.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 05-29-2014, 10:33 AM   #4
mrolds88
I am presuming that you are looking for an overdrive trans. There are several routs you can go. If you need to retain the mechanical clutch, then I would recommend the NV4500. Keeps the low first gear like the 465 and give you an overdrive. Plus it is a heavier duty trans. If you would decide that a hydraulic clutch could work for you , then an NV3500 would make a nice choice.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-30-2014, 01:48 PM   #5
hatzie
Moderator
hatzie's Avatar
The MY6 New Process A833 is about the only OD manual linkage clutch option.
I have 2 NV4500 transmissions. One is factory and one is a conversion...
Adding a Gear Vendors Overdrive to the SM465 will give you the same OD as the NV4500. It'll end up being much less time and around the same money spent... And you'll be able to tow in OD.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-30-2014, 01:51 PM   #6
95 S_Trucker
95 S_Trucker's Avatar
An 85 would of had a hydraulic clutch from the factory.
I second the NV4500.
95 S_Trucker is offline   Reply With Quote
Old 05-30-2014, 05:05 PM   #7
hatzie
Moderator
hatzie's Avatar
Yeah. My 85 & 86 did but the OP was asking for manual linkage options...
Old 05-31-2014, 10:16 AM   #8
angertheloner
These are great options. Thanks! I'll have to double check the clutch on the 85. I swore it was a manual linkage, but I may have been thinking about my 78.
I'm interested in that Gear Vendors overdrive. I'll check that.
I'm sure I'll have some questions once I double check it. Thanks again. I'm sure a hydraulic linkage would open up a work of possibilities.
Old 05-31-2014, 10:49 AM   #9
angertheloner
So it is a hydraulic clutch. So my question now is for 5 speed options? I don't need to haul anything.
I would like to keep the cost as low as possible, so has anyone mated a c1500 5 speed to an 80s 350? If so, did it require any mods?
Old 05-31-2014, 12:36 PM   #10
hatzie
Moderator
hatzie's Avatar
The NV3500 will handle the power output of a stock mid '80s 350. Max torque on the NV3500 is 300 ft/lb. Towing is basically out with that tranny. The gearing is more like a car tranny than a truck tranny.
The SM465 is essentially a 3 speed with an additional Low... the NV4500 has the same gearing with the addition of an OD gear.
The NV4500 is a heavy beast like the SM465. This swap can easily run into the $3000 range. That's the first reason the Gear Vendors is a good option.
You can tow with the NV4500 but... DO NOT TOW in 5th gear. This is where the Gear Vendors OD unit blows either 5 speed out of the water... You CAN tow in OD with a Gear Vendors unit without blowing the OD all to pieces.
If I had the 76 to do over I'd do a Gear Vendors OD unit...
If you must have the NV4500...
The 96+ transmission has the internal slave cylinder. The 93-95 unit has an external slave similar to the 85 but low on the RH side. Mating the slaves to the 85+ MC with a hybrid hydraulic line is part of the fun... I used a 96+ unit.
93 only has an extra low L (1st). Extremely rare so you prolly won't see one.
Make sure the *$&% salvage yard includes the bellhousing and shifter... No bellhousing? Don't be shy... Tell em why the sale just evaporated.
Old 05-31-2014, 01:24 PM   #11
roundhouse
Im researching the same swap,
I dont tow, and just want a commuter rig not a rockcrawler,
I had a T-18 in my Bronco and swapped in a NV3550. and I love it.
its perfect for street driving.
the SM465 totally sucks for daily street driving, even with the addition of the aluminum top cover and short throw shifter.
heres some info I found, it seems that if you have a 6 bolt Tcase with a 32 spline input shaft, then its a direct bolt in swap.:
http://coloradok5.com/forums/archive.../t-284816.html
The S-10 NV3500 will not work for your application. While they will bolt onto your engine, they use a 5 bolt round bolt pattern for the transfercase instead of 6, and the shifter is right at the very tail end of the transmission, putting it up through your floor right about where your center console sits.
You need an NV3500 from behind a 4.3L V6 or 5.0L V8 (and rarely, the 5.7L) from a 96+ K1500. Absolutely avoid any NV3500 with an external slave cylinder on them. Not only does the slave interfere with your front driveshaft unless you've got a bunch of lift, but they are also extremely weak, and break very frequently even with just light and normal use. They also use a very crappy shifter assembly which frequently falls out of gear.
In about 96 they switched to an internal slave transmission, which is what you want to find. I am not sure exactly when they switched it, but there are two versions of shift rails. One is a single rail, and the other has several rails. You want the version with a single rail on it. They are the strongest version of the NV3500 from 88-98. GM continued using the NV3500 until at least 05, possibly up until 07.5. These transmissions are the ultimate in strength, and came behind 4.8L V8 engines which make more horsepower and torque than a Vortec 5.7L. I have one from an 04 in my K5, and have had no mercy with it power shifting and dumping the clutch over and over on it while mud bogging at full throttle with my 6.2L turbocharged diesel engine offroad, with poor gearing and 37" boggers with lockers. No signs of failure at all, no unusual noises etc.
Swapping them in is not a difficult task. They bolt straight in place of your SM465, using the same transmission crossmember in the same position, using the same mount even. They all have a 32 spline 6 bolt round pattern so you can use an NP241 or NP208. NP205 would not be a good choice, as there is no place for the shifter bolt. The clutch is the same as your SM465, no need to change the flywheel, disc or pressure plate. You need to use the hydraulic throwout bearing, of course. The shifter on these trucks sits a few inches back of the SM465, requiring you to cut the floor back a bit, and patch it up at the top. If you want to use the stock shifter boot, you will need to move the NP208/241 shifter back a few inches and shorten the shift linkage under the truck to match. To match the hydro clutch, I personally retrofitted a 93 K3500 bolt on type master cylinder onto my truck. I drilled a hole through the clutch pedal and used a 1/2" bolt with the head cut off / hole drilled through for a hitch pin to attach the linkage to the pedal. I have heard rumours, but have not tested just yet (give me two weeks...) that you can simply splice an 85-91 stock master cylinder to the clutch hose for the internal slave and use it without any trouble. Try at your own risk, you have to buy the master and the slave to get a new hose from GM. The reverse light wiring is a plug in kind of a deal, same connector as your SM465.
Let me know if you have any other questions or run into trouble!
roundhouse is offline   Reply With Quote
Old 05-31-2014, 03:35 PM   #12
MalibuSSwagon
Alot of that stuff doesn't apply since you are 2WD.
98-05 S10 NV3500 have the shifter 6 inches further rear-ward. Earlier S10 versions have them in the same location as the 1500 trans.
MalibuSSwagon is offline   Reply With Quote
Old 05-31-2014, 07:53 PM   #13
roundhouse
but the 96 and older versions are unreliable, according to everything Ive read,
weak syncros, weak bearings, weak shift rails.
but youre right, for a 2wd it should be an easy swap.
Old 06-01-2014, 07:31 AM   #14
Desert1957
Desert1957's Avatar
Hatzie,
I am considering this NV4500 swap for my SM465 , Just curious about not towing in 5th gear?
This was the main reason for my interest. Do you have first hand knowledge of problem while towing in 5th?
Thanks Desert
Desert1957 is offline   Reply With Quote
Old 06-01-2014, 08:16 AM   #15
Edahall
I believe not towing in 5th gear with the NV4500 was related to extremely high torque engines like the Cummmins 6BT. Towing in O/D would cause the 5th gear nut to back out resulting in loss of that gear. There are fixes for this issue but it may be a non issue behind a 350.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 06-01-2014, 08:19 AM   #16
Desert1957
Desert1957's Avatar
Old 06-01-2014, 09:42 AM   #17
MalibuSSwagon
There is also the Ranger Overdrive option for guys that tow and like shifting....I was considering this option versus the NV4500.
Old 06-01-2014, 12:08 PM   #18
Edahall
Another option is to swap 2.73 gears. However, I don't know if it can be found in 3/4 ton axles.
Old 06-01-2014, 12:41 PM   #19
MalibuSSwagon
2.73 gearing works quite well with the SM465. Still tows decent too. Won't be the fastest thing around, but no such thing as "fast" and "budget" together.
Old 06-01-2014, 01:47 PM   #20
83GMCK2500
I am both surprised and not at the NV-4500 misinformation in this thread...
Introduced in '92, cast iron case, 5-speed OD, top loading, dual PTO ports, external slave mounted low on passenger side (GMT-400 platform has front driveshaft through same area on driver's side), ratios as follows: 1st - 6.34:1, 2nd - 3.44:1, 3rd - 1.71:1, 4th - 1:1, 5th - 0.73:1, R - 6.34:1. Unchanged in '93. Unchanged in '94. Changed in '95 (same year D*dge introduced it): new ratios: 1st - 5.61:1, 2nd - 3.04:1, 3rd - 1.67:1, 4th - 1:1, 5th - 0.75:1, R - 5.61:1; some still external slave, but new bellhousing-case bolt pattern matching D*dge pattern and internal slave/throwout bearing assembly introduced at some point in '95. (AdvanceAdapters states that they have encountered an early low gear ratio '95 MY case with new bolt pattern on case). Other changes later on internally, reverse lockout, and some other small doo-dads, can't find clear documentation on when/what changed.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 06-01-2014, 05:29 PM   #21
hatzie
Moderator
hatzie's Avatar
There's some confusion on the "super granny" 1st. Dodge had 5.61:1 1st/rev in 93. I'm not sure whether they ever had the 6.34:1. I don't have documentation that shows it. Allpar claims the 6.34:1 was a GM-only thing and only through MY 94. I know there were 5.61:1 units on MY 94 trucks... I bought one thinking I was getting the 6.34:1 ratio 1st for a 2wd tow rig. Optional ratio or early MY 94 production when there were still a few in the pipeline from 93?? Don't know. The likelihood of an unmolested Dodge pattern GM NV4500 with 6.34:1 1st/rev is low.
The change from external MT8 to internal slave MW3 was likely close to the 95 96 MY production split.
I was unaware there were Dodge pattern trannies with external slave bellhousings. If they exist it makes getting the original piece, still attached, even more important.
The MW3 got reverse synchros in 1998 or 99.
I stand by my comment on 5th gear towing. The retaining nut can back off and screw up the mainshaft and the gear. It's a known issue...
Old 06-02-2014, 11:19 AM   #22
Desert1957
Desert1957's Avatar
Good info in this thread , I was trying to keep the stock clutch and cross bar.
I thinking about the "Advanced Adapters" kit which looks like it has everything I need for my 2WD swap.
I will modify the trans cross-member and driveshaft
Name:  Advanced Adapters.jpg
Desert
Old 06-02-2014, 04:05 PM   #23
95 S_Trucker
In the owners manuals in these trucks, Its says not to tow in fifth gear.
