06-03-2014, 01:05 AM | #1 |
Simple? What's simple?
Hydroboost into a 67-72
I did some research on this a while back, and it seemed like every thread I found talked about drilling holes in the firewall or other modifications that made this swap difficult to do.
In looking at donor trucks, it seems like only the metric (1980+) trucks had the type of booster I'm working with here. Anyways, some pictures: Comparison between an unmodified '87 hydroboost bracket and my '72 power brake booster Lining up the center holes puts the pushrod in the center of the hole in the firewall. I should note that the hydroboost had two pressed-in studs in the center holes, which I popped out. Using two snug fitting bolts and a welding clamp, I carefully lined up the two holes and marked for the other holes I needed. It's tough to see here, but there was a stamped bend in the top of the hydroboost, which I pounded flat prior to marking (just below the top holes) After drilling three new holes and some cutting and grinding, this is what I came up with. The cut on the bottom right was to allow me to bend the bracket out slightly to clear the flange around the steering column on the firewall. Bracket dry fit on my '72 cab And here's the donor hydroboost bolted in place I had to make zero modifications to the firewall, except pulling out the original rubber linkage boot. The photo doesn't show, but mounted like this the hydroboost pushrod is about 5/8" too short (and offers no adjustment). Unfortunately it's a smaller diameter than the adjuster end on the 67-72 style pushrod, so either I will cut and thread the rod and thread a piece of tubing to make an adjuster of my own, or I'll modify the pedal to move the pivot closer to the firewall.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 08-17-2015 at 12:41 PM. |
06-03-2014, 01:17 AM | #2 |
Re: Hydroboost into a 67-72
Cool thanks for the post i have the booster and am doing this to my 68 !
06-03-2014, 01:52 AM | #3 |
looks good
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
06-04-2014, 09:18 AM | #4 |
Very nice, thanks for sharing.
How is the pressure and return line plumbing going? Are you using all the stock lines the the 80+ truck? Are they flare or O-ring lines? What are you doing to get two return lines into your reservoir housing? |
06-04-2014, 10:27 AM | #5 | |
This is happening at the same time as my 2wd to 4wd 1 ton swap, so I probably won't get to finalizing the plumbing for a week or so and I will update this thread when I do. More info on the swap here
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
06-05-2014, 06:32 PM | #6 |
Had a few spare hours this afternoon - modified my brake pedal to work with the pushrod for the hydroboost. That way, if the hydroboost ever has to be replaced, it's a bolt-on.
I've put it all together, it works, I've painted the pedal and I will get some pictures once it's dried and I can put it back for good.
06-05-2014, 07:04 PM | #7 |
Great this will make my swap easy!
06-05-2014, 07:26 PM | #8 |
Divorced .....WITH KIDS
I'm new to the power brake / hydra boost swap . What's the difference between them ?
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
06-05-2014, 11:45 PM | #9 | |
The functional difference for us is that the 67-72 came with power brakes, you can just bolt it on, where hydroboost was first available around '74 or '75, that I know of. So, basically to make a hydroboost work you need new power steering lines, a modified mounting bracket for the firewall, and either a modified push-rod or a modified pedal (as I did in this case)
06-06-2014, 11:01 AM | #10 | |
06-06-2014, 11:19 PM | #11 |
1 thing at a time is progress.
Subscribed
Alan
Philippians 2:14-16 |
06-27-2014, 10:54 PM | #12 |
I don't have any photos yet, but status update:
With the modified pedal, the hydroboost unit fits nicely and is installed for the final time. The '87 truck brake lines actually fit in the '72 almost like they were meant to go there I was able to successfully swap the pressure outlet fitting in my PS pump to the later metric unit, and the '87 pressure line fits nicely (they're a tad longer than needed but it is nice to have the extra for neat routing). I had to make a couple small tweaks to the line shape, but it was nearly a bolt on affair.
08-02-2014, 12:57 PM | #13 |
Well I am WAY behind on my photo updates, but I finally got a chance to get some photos of how this turned out:
First, overall engine bay shots These are regular issue 1987 V30 hydroboost lines (Eldelman power steering lines and Inline Tube stainless brake lines) Detail shots of hoses. I chose to use the '87 steering box on my '72 frame to make the plumbing easier I also retained the original '72 power steering pump, which required a tee in the return lines Just a few notes. 1. I did have to tweak the PS lines, and also the inner fender, a bit at the steering box to make everything fit but it all clears and no cutting was required. 2. The original PS pump has a smaller reservoir than the newer style pumps; initially I thought this was an unsolvable issue because I was getting aeration when turning and using the brakes at the same time. However, after some road time and bleeding the system out I've eliminated that and am happy to report no problems. 3. I read a bunch here and elsewhere about not using a "T" in the return line as it would starve the pump. After doing some research, the first years of GM hydroboost trucks (up until about 1980) were designed with a "T" in the system. Provided you use a tee of the appropriate ID, this is NOT a problem at all. Overall, could not be happier with the swap. Very consistent, solid pedal feel across all different engine and truck loading conditions, and it is so very much cleaner under the hood.
08-02-2014, 03:00 PM | #14 |
Subscribed also. This is a conversion I'll do eventually. I love the hydroboost in my diesel DD's
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-02-2014, 05:00 PM | #15 |
Good job on the swap. It really cleans up the firewall.
08-03-2014, 01:28 PM | #16 |
Very nice
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
08-03-2014, 02:38 PM | #17 |
Keepin an eye out
Have HB on my truck the previous owner installed...One thing I can say is if I ever need to hit the brakes hard im sure I will be going through the windshield.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
08-03-2014, 09:55 PM | #18 |
Awesome so a stock power steering pump works with a t on the return!I am going serpentine belt so i will use a pump from the same year i take the set up off of 1996 most likely.
10-06-2014, 09:58 PM | #19 |
Great job as usual, subscribed!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
10-06-2014, 10:36 PM | #20 |
where did you mount the prop valve?
10-07-2014, 12:37 AM | #21 |
Since I was using the square body lines, I mounted it on the front cross member just like they do. I used the square body cross member for the sway bar mounts, but the same position will work on a 67-72 cross member no problem
I happened to have a second '67 truck harness laying around, and the harness - prop valve wire is made in two pieces with a connector where it leaves the main harness. By pulling that piece off my spare harness, I was able to plug into the extension already on the '72 and reach the prop valve on the cross member no problem.
07-20-2015, 02:43 PM | #22 |
07-20-2015, 04:18 PM | #23 |
Hydroboost would have come from a 1 ton truck
07-20-2015, 04:32 PM | #24 |
Wide n'Low
Astro vans are another common source for the hydro-boost unit.
You may already know, but there are some great threads covering the conversion to go along with this one. http://67-72chevytrucks.com/vboard/s...d.php?t=523502 http://67-72chevytrucks.com/vboard/s...d.php?t=372984 http://67-72chevytrucks.com/vboard/s...d.php?t=539517 And to make things even easier for some, CaptainFab has adapter brackets http://67-72chevytrucks.com/vboard/s...d.php?t=347480
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
07-20-2015, 06:33 PM | #25 |
I have a 78 gmc 1/2 ton that had a diesel in it new but now has a 350 in my shop that im wrecking but the brakes did work. should I take it off before it hits the scrapper? Hoses would all need to be changed if I reused this set up. seems like its going to be a messy situation.
