Old 06-05-2014, 12:09 AM   #1
mr.chevyblack
mr.chevyblack's Avatar
how to fill a blazer tank in a truck?
installing a blazer tank in the rear of my new project truck crew cab short bed cummins wanting some pics or ideas on how to fill?
mr.chevyblack is offline   Reply With Quote
Old 06-05-2014, 07:51 AM   #2
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: how to fill a blazer tank in a truck?
Here's how I did it. I remover the original filler neck with heat removing the solder. I then bought a custom fuel tank filler neck (lot's of places sell them) and bolted it right over the original hole. I then installed a door in the floor of the bed. Easy enough. Pics:
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 06-05-2014, 07:59 AM   #3
JWall
Frequent Flyer
JWall's Avatar
Here is mine.
It was originally mounted in the same spot but straight to the bed floor with the original style gas cap but it wouldn't fill very well because of the pretty much immediate turn in the filler tube so we raised it to give it more filler tube before the turn. It now works great & will fill with a gas pump at full speed.
- Justin
1 Owner 1976 SWB
Old 06-05-2014, 03:06 PM   #4
kevinr1970
I was wanting to do this same tank setup in my swb.
My thought was to move the gas fill door to a rear location like a Blazer or Suburban.
Any reason that wouldn't work?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 06-05-2014, 07:43 PM   #5
Mr.Chevy4x4
You might have to notch the frame to get the fill tube out there? Not sure. I thought about the same thing then went the easy route.
Old 06-05-2014, 10:56 PM   #6
riz
I'm planning of using a Blazer tank on my 81 c-10 swb and hide the filler behind one of the tail light assemblies. I've seen it done on the web before and I really want to try it but afraid I won't be able to pull it off since I'm fairly new to doing these types of mods. I can use all the help I can get.
RIZ
riz is offline   Reply With Quote
Old 06-06-2014, 10:27 AM   #7
school boy
school boy's Avatar
subscribed!
school boy is offline   Reply With Quote
Old 06-06-2014, 06:52 PM   #8
y5mgisi
Second Chance Program
y5mgisi's Avatar
Also subscribed. I had planned on using everything from a suburban.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
