Old 06-05-2014, 10:28 PM   #1
Parishchief1
Parishchief1's Avatar
Lsx376 2.9l whipple?
I'm building a 67 c10 and I've weighing my options on which motor to go with, I've been looking into the lsx376 b15 with the forged rotating assembly with a 2.9 l whipple supercharger setup. Just not too sure which injectors, coils, ect. To use to complete my build and will it clear the stock hood?
Parishchief1 is offline   Reply With Quote
Old 06-06-2014, 12:29 AM   #2
littlevictories
Re: Lsx376 2.9l whipple?
the answer is yes
littlevictories is offline   Reply With Quote
Old 06-06-2014, 07:32 AM   #3
Parishchief1
Originally Posted by littlevictories View Post
the answer is yes
Ok thanks, but I'm buying the short block and I'm not sure what all is needed to complete my build?
Old 06-06-2014, 10:14 AM   #4
littlevictories
you can figure injector size by working backwards from your estmated max torque goal. get that number, figure the fuel needs for it in lbs per hour and calculate the injector size from that.
here's a link to a calculator, but like anything free it's usually worth what you paid for it.
http://www.witchhunter.com/injectorcalc1.php
Use it as a ballpark, but it's best to talk with your tuner since he will likely have an opinion on what works best for a given set-up.
Old 06-06-2014, 10:18 AM   #5
Parishchief1
Thanks I'll try that, I've never built an ls motor before so I'm not sure what all is needed to complete my build like what coil packs to use, what ignition to use ect I need someone to kind of give me a parts list. Lol
67' C-10 PBFAB suspension,Accuair, Baer Pro+ 14" big brake kit F&R, Narrowed moser 12 bolt,Boyd Slayer 24x9's & 24x15's. 405 GANG500HP Ls "Da Green Beast"
Old 06-06-2014, 10:20 AM   #6
littlevictories
Oh gotcha. You know what computer/wiring harness/tuning software you're gonna use? that'll make sourcing sensors and other bits a lot easier.
Old 06-06-2014, 10:27 AM   #7
Hart_Rod
Hart_Rod's Avatar
I have a TVS1900 on a LS3. Check out my 68 S/C build thread. Factory coils will work just fine. I'm guessing you will need around 60 lb injectors (@58 psi should give you 70+ psi at the rails). You will also need a boost referenced fuel pressure regulator, wihich requires a return line to the tank. I also installed a Boyds tank that has an Aeromotive A1000 intank pump that is supposed to be good up to 1000+ HP.
Hart_Rod is offline   Reply With Quote
Old 06-06-2014, 10:28 AM   #8
Parishchief1
I'm was referred to spear tech for harness and ECM
Old 06-06-2014, 12:37 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
May I ask, if you've never worked with an LS motor....how exactly did you decide on an Lsx376 and a whipple? There are plenty of options to build a high hp ls motor, but the one you picked is an "off the catalog page" sort of thing.
Speartech is pretty well known, but I'm not a fan of mail order tuning, you can put together the same stuff from other sources. Mail order tuning something that high in power leaves huge room for error. That would by something that should be tuned in person, on a dyno.
Things like "what coil packs" really don't strike me as the right questions to ask. How about, what fuel system are you going to run? Have you picked a trans? I think more of the small stuff will fall into place for you, if your concrete on the bigger plans.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-06-2014, 01:31 PM   #10
Parishchief1
No never worked on an ls before, and I chose the lsx376 with a whipple because I want to do a supercharged setup and I did my research and the lsx376 b15 is the perfect out the box crate motor for boost. I wanna run a magnum t56 and a Boyd fuel system
Old 06-06-2014, 01:57 PM   #11
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
I would suggest thumbing through a few lsx build threads on here ( start with Hart Rods, lots of good info and details) Most of us have previous LS experience from when our drivetrain donor vehicles were still on the road. Lots of noob questions (no offense) can be answered by looking through some builds. You have a lot to wrinkle out yet before wrench time starts, game plans on projects like this will save you $$$, time and headaches
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 06-06-2014, 02:39 PM   #12
Parishchief1
Yes I am a "noob" this is my first project, I'm just looking for answers and tips to point me in the right direction,
Old 06-06-2014, 04:56 PM   #13
RocketChevy56
Answers are most definitely amongst you. I think you just had a few questions that were a bit ahead of themselves. If your set on a decently cubed lsx and want to go supercharged. Then no harm, no foul on the motor choice. there are tons of other options but to each his own, and your choice will do the job. next would be transmission. Running a t56 will give you lots of good options as far as clutches go to hold the power. I've heard good things about the speartech harnesses, supposed to have good quality wire and connectors. Might wanna scroll through some of our vendors and see if they can cut you good package deal since your just getting rolling. Is this motor complete? cam etc? do you plan on running LS car or truck front drive? What swap mounts/headers are you going to use? Its ok if you do or don't know all the answers, just something to get you started thinking about and planning so you can build around it and get you a game plan. We are all here to help each other so don't be afraid to ask anything but try looking around first, most general ls questions have been redundantly answered, doesn't mean we won't answer again though lol Happy LSX'ing!
Old 06-06-2014, 05:02 PM   #14
Parishchief1
Yeah the lsx comes with the cam,heads, pretty much everything, not sure which headers will fit I've heard new style camaro headers but not too sure, I've also looked in twin carbon plate clutches from lingenfelders.
Old 06-06-2014, 05:03 PM   #15
Parishchief1
Not too sure on which front drive to run?
Old 06-06-2014, 05:30 PM   #16
RocketChevy56
I would think you will likely have to run a car acc drive only for the clearance for the supercharger. Hart Rod might should chime in on that one and verify though. Mccleod makes some pretty wicked twin discs. Their street twin makes it easier to drive on the street if you plan on cruising and bruising. As far as headers go, if you don't plan on buying a direct bolt in swap headers like Doug Thorley, then I believe the trailblazer SS LT's are the closest to fitting the best. I've heard mixed things about having to shave a little off the frame rails but that seems to be the only issues I've personally heard about.
Old 06-06-2014, 05:33 PM   #17
Parishchief1
Yeah I was looking at the Doug thorley swap headers
Old 06-06-2014, 05:39 PM   #18
RocketChevy56
They are really nice and top quality. I've never used their swap headers but I have put a few sets on 4th and 5th gen camaros. They also get spendy fast
Old 06-08-2014, 04:15 PM   #19
Parishchief1
Bump
Old 06-09-2014, 12:23 PM   #20
littlevictories
you might wanna make a trip over to Ls1tech's forced induction forum.
Old 06-10-2014, 05:09 AM   #21
c10seconds
c10seconds's Avatar
With that LSX motor you will have a tough time finding a set of headers that will work because of the six bolt heads. I know that the Trailblazer ss kooks LT's will not work with the extra tabs on the heads. I was able to put together a pretty stout forged "LS3" for much less than that lsx crate motor will cost you.
I can also tell you that the 2.9 whipple will clear the hood just fine. It sits up high but clears the 67 hood. For injectors I went with ID850's. I have the LS3 C6 whipple so I have the corvette accessories. You'll also need a fuel system to go with that 2.9 whipple.
This stuff really adds up quickly. I guess it all depends on how deep your pockets are.
1967 C10 SWB 6.8L/4L80
c10seconds is offline   Reply With Quote
Old 06-10-2014, 09:19 AM   #22
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Parishchief1 View Post
Bump
You could just buy my truck and save yourself some time and $$$$..........
Old 06-10-2014, 09:46 AM   #23
Wasted Income
Boosted Member
Wasted Income's Avatar
^ This.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-12-2014, 10:21 AM   #24
Parishchief1
I talked to a tech at whipple and he's telling me to make 700rwhp I would have to run the 4.0l whipple which sits 13" off of the block and I don't think that monster will fit under my hood, I'm running a 2" cowl hood. Which ls coil packs to use? The ls3 style? And what fuel system are u guys running a know fast makes a gen 3 kit and mast performance has one capable of 1200 hp
Old 06-12-2014, 10:49 AM   #25
Hart_Rod
Hart_Rod's Avatar
I'm 600+ with a fairly mild cam (219/235 113 LSA (607/621)), dual valve springs, stock LS3 bottom end, stock LS3 heads, 10.4 CR, 1 7/8" headers and a TVS1900 (8 pounds of boost). With a more aggressive cam and meth injection, I think I could easily be at 700 RWHP....
