Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 06-08-2014, 11:59 AM   #1
Horacio
Horacio's Avatar
64 Panel Barn Door Latches
Hi I'm looking for info if the latches for the barn doors are available anywhere. I have just taken possession of a 64 and the rear latches have some slop in them. the weather stripping is not on but the bottom latch does not seem to catch. I have tried adjusting them to no avail, any info or guidance is appreciated.
Thanks!
Horacio is offline   Reply With Quote
Old 06-08-2014, 01:00 PM   #2
Horacio
Horacio's Avatar
Re: 64 Panel Barn Door Latches
So after some picture searching I've found out someone had installed the bottom catch the wrong way, flipped it and were good!
Old 06-08-2014, 01:47 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Nice looking panel! Once you get the weather stripping on, it will also tighten up the rear doors. They are sloppy without the strip. Glad you figured out the latch issue.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
