Old 08-03-2003, 04:14 PM   #1
lash
700r4 in 4x4
I read the post in the faq forum on installation but didnt see anything about 4x4 installation. Is there any modifications needed or differnt tailshaft. Also how much rpm and torque loss is there between 1st & 2nd compared to a th350. I am running a stroker w/ 450+ hp. Thanks for any info. Lash
lash is offline   Reply With Quote
Old 08-03-2003, 07:46 PM   #2
86k10
Changing to a 700 r4 will require you to change both driveline lengths and move your crossmember. As far as loosing rpms and some power I would say yes you'll loose some since a 700 has a 1st gear ratio of 3.06 and a 350 has a 2.52 ratio first and i'm thinking 2nd is about 1.63 in both so I think you can see the difference. But if you have enough ponies under the hood you should be ok. I would say a stock one should handle your horsepower numbers but anything higher than that it should be beefed up a little.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 08-03-2003, 08:57 PM   #3
sano_surfer
I have put a 700r4 in a 4x4 and it is no big deal.
leave the t-case in it's current location. by doing this you don't have to touch the drive line lengths and you don't have to cut a new hole in your hump for the t-case!
All you need to do is move your engine forward 1.5 inches, modify your autoshift linkage and add wiring for lock up torque converter. NO problema and the modification makes driving the truck a dream! I have the fact 3.73 gears and am running 32" tires and am really happy. Oh yeah one other thing that you might have to deal with is the exhaust hangers. mine had to be changed slightly due to moving the engine forward.
Take care. Tom Rutherford (aka 1971short4x4) i'm not san_surfer..just using his login..as he used my computer last.
Tom
sano_surfer is offline   Reply With Quote
