06-16-2014, 08:32 PM | #1 |
www.73-87chevytrucks.com
73-87 Pillar Pod final questions
Last and final questions before the pillars are signed of for production...
You can see all the progress on these here, skip to the end if you want the latest. http://forum.73-87chevytrucks.com/sm...?topic=16193.0 1) currently these are sized to fit Autometer gauges of 2-1/16, that means others won't slip in and be tension held. Should I make is smaller and have a step in it on where to trim to for the Autometers or just make it fit Autometer and anyone using other generic gauges have to use the clamp set? (many people don't clamp these) 2) Is everyone going to be drilling holes in their pillar to route the wiring/hoses? What is your plans on routing? 3) How is everyone planning on attaching these? What is you plan on attaching these? I am ready to fire the trigger on this and this is how I planned to go about it, but feedback is welcome. I cannot accomodate everyones wishes though. 1) make it fit the Autometer body 2) drill a pass through hole if required in the pillar or for wiring wrap it under 3) I plan to permanently mount mine with either epoxy or plastic weld.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-16-2014, 08:41 PM | #2 |
yeller
Re: 73-87 Pillar Pod final questions
Nice job Chris! These should sell like hot cakes!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-16-2014, 09:03 PM | #3 |
Diggin The SquareLife
would air ride gauges fit in these? I would like to run my air pressure gauges in one of these
06-16-2014, 09:51 PM | #4 |
I know you can't make everyone happy but if it was me......I would build them with a smaller 1 1/2" or 2" opening allowing the ability to trim out to a larger size to fit your autometer gauges. It just allows for more options IMO. The options to outfit with smaller or larger gauges should help the sale of your product.
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
06-17-2014, 01:41 AM | #5 |
Sweet. I'd be fine with the autometer press fit. They have a good variety of gauges and lots of styles.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
06-17-2014, 08:15 AM | #6 |
Nice work! I recently had a friend with a K5 Blazer who is not on the forum ask me if anyone makes a gauge pod for the door pillar on our trucks.
06-17-2014, 09:30 AM | #7 |
Any 2-1/16" gauge should fit in the opening as it is. Some that have bodies smaller than the Autometers will just require the retaining bracket as it is. This includes several of the cheaper gauges.
I chose the standard offering or 2-1/16" for gauge sizes based on other offerings and feedback many years ago. Keep it coming...
06-17-2014, 09:35 AM | #8 |
06-17-2014, 11:39 AM | #9 |
I know the other thread said these will be offered in triple only but I hope a lower single does become available.
As a bike rider, that middle pod is placed to do a good job of hiding a bike or pedestrian. A low single would be a good solution to where to put a tach gauge without blocking my scan pattern. |
06-17-2014, 01:03 PM | #10 |
What will be the price on this?
06-17-2014, 01:17 PM | #11 |
I ride motorcycles myself. I can assure you that pod not being there is not going to make it any safer for you. You have to worry more about the nut behind the wheel. By the time they get to where that pod is, they will be well past you. I drove it like that for over 2 weeks.
If you compare what is blocked on the 73-87's compared to a newer trucks, what is being blocked is nothing in comparison. Pricing hasn't been set yet as it will need to be finalized.
06-18-2014, 03:00 AM | #12 |
A lot of people will love you once you get them going.We have had a few post about where to find one and no one makes them so you got the market cornered if the price is right.
06-18-2014, 03:52 AM | #13 |
At the body shop.
Will they work on a truck with out a headliner. Just the bare A pillar?
" That didnt make it any newer " " Dont antique the equipment " |
06-18-2014, 10:06 AM | #14 |
Im with Chevy3+3. Maybe no hole at all. Customer cuts to fit ?
I would like to put an LED shift lite in it !!! |
06-18-2014, 12:55 PM | #15 |
yeller
Doesnt look like it will to me...of course you could modify it to pretty easy i would assume.
06-18-2014, 01:27 PM | #16 |
So how well would it mount with double sided Velcro or 3M strips? And when I got my rod door speaker pods for my kick panels they were solid. It was a pain but it was nice knowing my speakers would be a custom fit and would work maybe make some pods that aren't cut so other gauges can be used or custom fitted?
I'm also assuming I can just cut it to the desired amount of gauges like 1-2-3 I'm in for a set!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
06-18-2014, 01:46 PM | #17 | |
06-18-2014, 11:47 PM | #18 |
Just means you can have it in different spots still then right? I would love to have my oil temp and a/f up there
06-19-2014, 11:09 AM | #19 |
I know the pieces fit
Can not wait for these. Last time I did this I drilled a hole in the existing A-pillar trim and ran the wires through, then used small screws to attach the gauge pod to the factory trim. And I vote for them to be fit to AutoMeter gauges.
07-02-2014, 01:15 AM | #20 |
I don't know that I am going to do no hole at all. I don't think most people will want to try and center a hole in there. I am probably going to make a 2" hole and then you can trim for size from there. This will allow the end user to use cheap or expensive gauges.
The pillar is curved in 2 directions. Where they are there is about 1/2" of variance. They will probably be attached with screws or "pins". Which is what I am looking for feedback.
07-02-2014, 12:40 PM | #21 |
yeller
Chris, what about providing a center hole or indent...this would allow for easy drilling of the correct size opening for the gauge the customer ends up purchasing. Just a thought.
07-02-2014, 03:16 PM | #22 |
Old Heap Driver
That and maybe a template in various sizes a person could use to scribe a cut line.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
07-03-2014, 10:26 PM | #23 |
have you made a single pod to fit in the steering column? by the way it looks killer
07-04-2014, 08:14 AM | #24 |
looks good, i'll be wanting one...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
07-07-2014, 09:09 AM | #25 |
Are we there yet !?!?!?!
I want one, or two, or three..... |
Tags |
73-87chevytrucks, captkaos, pillar pod, roundedline |
