06-19-2014, 10:59 AM | #1 |
Bed Mats, Old Question?
I've searched high & low for a rubber bed mat that would "Fit" my 68 GMC short bed fleetside and have only found a company that sells over-sized rectangular 3/8 thick mat you have to cut. Does anybody Know of a "Made to Fit" rubber bed mat 3/8" thick or thicker available and from where?
Thanks Lee
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
06-19-2014, 12:20 PM | #2 |
Re: Bed Mats, Old Question?
A "Made to Fit" rubber bed mat for this vintage is no longer made. I have searched and searched. The closest I could find is ProTecta brand part number LRV-6642D, I got from Summit Racing $70 bucks. This is a 73 up, and only available in the long bed version, cut to fit for a short bed. The one issue with this mat is the wheel houses of 73 up are about 4 inches longer than the 67-72 so there will be a gap. When cutting to fit I split the difference so there was only a two inch gap fore and aft of the wheel houses. It fits nicely between the bed sides and between the wheel houses. Not a custom fit but better than no mat, at least for me.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-19-2014, 12:24 PM | #3 |
I bought the Protecta 6721D.
It's an un-cut rectangle. I found it easy to cut with a little soap/water and a sharp box cutter. It's thick and heavy weight. Very satisfied.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
06-19-2014, 12:34 PM | #4 |
So Big dav you had to cut everything out including the wheel housings with this one? It's cheaper by the way ($109.00 + ship) than other 3/8 thick rectangular Cut to Fit mats I found.
Thanks Guys
06-20-2014, 02:20 AM | #5 |
Scrapper 1
there is another problem about putting any bed mat in Mold if water gets under it the wood will start to mold and get weak
