06-22-2014, 11:25 AM | #1 |
Intake woes
Hi all,
I finally got around to installing my sanden compressor on pass side with DD mount. Problem is, now I have to buy a new intake and was looking at either a u-build-it airaid or Spectre flex tube. Using the flex tube I will have to find a way to make my delphi MAF work. The space between the ac and the e-fan is barely over 4" and a 4" tube will fit but do I need a 4" tube? Will a 3" work fine? The engine is a stock 5.3 with tune and I am using a modified stock intake for now, does anyone know the diameter of that? Any thoughts would be appreciated. Ben |
06-22-2014, 01:49 PM | #2 |
Re: Intake woes
Not sure if its feasible for you and what you all have on the drivers side fenderwell....
I took my Spectre 9900 and flipped the tube backwards, went just above the alternator pulley on my 1966 c10 / 5.3... and put it to the driver side (is suppose to be on the passenger side)
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
06-22-2014, 02:21 PM | #3 |
meowMEOWmeowMEOW
Re: Intake woes
You need a Cobra Head
4" diameter, retains volume through bend by ovaling. Same concept as the supercar exhausts that oval out to pass under skid plates.
06-22-2014, 04:58 PM | #4 |
Re: Intake woes
Any info on where to get one, is this a Ford Cobra part number?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
06-22-2014, 05:17 PM | #5 |
meowMEOWmeowMEOW
Re: Intake woes
06-22-2014, 05:45 PM | #6 |
Re: Intake woes
Found it 90CB40 $27.xx
06-22-2014, 06:07 PM | #7 |
meowMEOWmeowMEOW
Re: Intake woes
fwiw I JUST bought a 90* regular elbow from AirRaid's BUI kit. Its thick plastic, pretty nice, but not perfect. The rubber stuff from intakehoses.com is the same rubber they use for Diesel truck parts, so its good to extreme temps and even hold pressure decently well (for boost-side stuff in other applications).
06-22-2014, 07:02 PM | #8 |
Re: Intake woes
Thanks for all the replies. What r the thoughts on 3" vs 4" tube?
06-22-2014, 10:36 PM | #9 |
Re: Intake woes
Looking at everything again I think I'm gunna undo part of my harness and run the MAF and intake on the driver side.
06-23-2014, 12:45 AM | #10 |
Re: Intake woes
It was easier than moving the battery!
06-23-2014, 01:06 AM | #11 |
meowMEOWmeowMEOW
Re: Intake woes
Devils advocate to you tho.....our IAT's really really SUCK under the hoods of these trucks. I had the same base intake, and the heat soak is terrible. The ecm also gets warm, so your putting the filter over another heat source.
Ideally, the intake filter needs to be seperated from the engine bay. I started addressing this myself recently, and had to built an intake heatshield, relocated the path, and I went and modded the core support as well. Pics and video are coming.
06-23-2014, 11:37 AM | #12 |
Re: Intake woes
Thanks Solid and Br3w. I m with ya on the IAT B, if I stand still too long the temps get up there quick so here is what I am thinking:
Are too many bends bad for intake? Also, anyone know of a MAF mount or do I need to purchase a new one? Br3w, is the airaid same thickness as the original intake tube? Also, I only have about 2" of clearance from the top of the rad, so not much room. Thanks again guys |
06-23-2014, 12:31 PM | #13 |
meowMEOWmeowMEOW
Re: Intake woes
Thats a similar path mine takes, just to the other side by the old battery spot.
The airaid tube is plastic, but it doesn't seem much thicker than the aluminum tube. Is your MAF the in-line, or is it the drop-in/blade style
06-23-2014, 02:00 PM | #14 |
Re: Intake woes
Like most everything I do, that is where I would like it to end up!
Go ahead and let me see how you made it work in the new position, and how many bends you used. I will need to cut the long pipe to make the MAF fit, as the wire lead is too short to move it to end by the filter. This kit also came with a "box" for the filter and I need to open up the knock out in the core support. I am sure it will drop the intake temp when it is complete. Keep me posted Ben
06-23-2014, 03:30 PM | #15 |
Re: Intake woes
YES!!! Found something I've been looking for for a long time. If you have the Delphi style MAF like I do here is the weld on bung or whole piece you can buy
http://mrpmachineshop.com/2014/04/30...10055-sensors/ This will help out a bunch, the bung is only $22 on ebay! Solid, I will keep you posted but the update will be a while as I go on vacation for a few weeks here soon! |
06-23-2014, 08:51 PM | #16 | |
Re: Intake woes
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold 1986 suburban 350/700r/3:73's 31's: parted out. 1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold 1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold 1970 c10 long bed-new project! getting ready for the 6.0 |
06-23-2014, 09:42 PM | #17 |
Re: Intake woes
I built a cold air box for my truck that pulls air from the front of the core support. I was driving home from Biloxi, MS yesterday and the OAT was in the low 90s. My IAT's were <115 while cruising and only climbed to 125 when I got in stop and go traffic for about 20 minutes. I plan on putting some fatmat inside the box to see if that will help bring them down some more.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-23-2014, 11:25 PM | #18 |
Re: Intake woes
Hart Rod can you post some more pics of your setup? Are you using a cone filter inside the box? Are you at all worried about water? Thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
06-24-2014, 12:46 AM | #19 |
meowMEOWmeowMEOW
Re: Intake woes
Intake is pretty much how it was, plus a 90* at the end into the box. Rough cut the core support on the intside to fit the nose of the filter inward (its long). Roughed out a base shape base for the outside from galv steel. Still gotta make a lid, mount the filter, mount all the weatherstripping, and clean it all up and coat the pipes etc. Prob going to weld the alum pipes together to remove the extra coupling.
I'm debating adding some gold heat-flect material since its cool
06-24-2014, 01:11 AM | #20 |
Re: Intake woes
Good idea Br3w, I like it, it should work at 180 * to the right.
Good point about water, like we see alot here, but a big concern with the air filter
06-24-2014, 01:53 PM | #21 | |
meowMEOWmeowMEOW
Re: Intake woes
In the core support, water would have to spray straight up, and even then it would only touch maybe the first 3" of a 7" filter. IF you really are worried about it, just put a dry-sock over the filter. They are pretty cheap, and the Jeep guys never hydrolok their junk, and they almost submerge em. OR you can put one of those "bellows" in the intake path, which helps prevent water from being sucked up, even if it does touch the filter.
06-24-2014, 01:53 PM | #22 |
Re: Intake woes
Here are a few more pics. I'm using a K&N cone filter. I supposed it could be affected by water but it's not a straight shot through the grill opening, so it would have to be raining pretty hard to affect the filter. If it's raining that hard, I will probably pull over some where, .
06-25-2014, 01:04 AM | #23 |
meowMEOWmeowMEOW
Re: Intake woes
Beat on mine for a little today. Sorry for Sh!t pictures, I'll get better ones, and the video.
A show of how it sat, for review. Inside edges are all seam-seal taped and there is rubber gasketing around the base and sides of the lid. Now I just gotta get the tube cleaned up, and decide on the finish of the box.
06-25-2014, 09:22 AM | #24 | |
Re: Intake woes
06-25-2014, 09:44 AM | #25 |
Re: Intake woes
Looks good Br3w! The older C10's must have more hood clearance because I can't run my intake that high off the engine, I wish I could as that would make things a lot easier!! Wish I could work on my truck NOW, but it has to wait till after vaca! BTW, what size pipe is that that you are running for your coolant?
