Old 06-23-2014, 09:39 AM   #1
dman1982
dman1982's Avatar
kinda wierd
so i hooked up my electric fans last night, they work awesome!!! they really suck!!! haha...but i called the guy that did my harness and he told me the red wire off the harness goes straight to the battery, well i think he was mistaken because when i hooked it up the low fan came on, so i hooked it up to a wire that comes on when the key turns on, well in doing so now when i turn the truck off it runs for about 2 or 3 seconds after i turn the key off....anyone ever see this? (i mean I've seen it on older engines when the timings off) but not on one of these
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 06-23-2014, 01:03 PM   #2
dman1982
dman1982's Avatar
Re: kinda wierd
nobody? thats weird too!!!
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-23-2014, 02:31 PM   #3
solidaxel
solidaxel's Avatar
Re: kinda wierd
That happens!
Place a diod(SP) in the circuit or a relay, that should do the trick!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-23-2014, 02:32 PM   #4
dman1982
dman1982's Avatar
Re: kinda wierd
Huh?? Lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-23-2014, 02:36 PM   #5
solidaxel
solidaxel's Avatar
Re: kinda wierd
Originally Posted by dman1982 View Post
Huh?? Lol
The circuit that is feeding the fan, someone will draw you a pic, I am not able to draw!
Your fan is creating a back feed or generating current until it slows down
LS 3 4L70E
Old 06-23-2014, 02:40 PM   #6
dman1982
dman1982's Avatar
Re: kinda wierd
im runnin a high fan and low fan, should i just have them both going at the same time?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-23-2014, 02:52 PM   #7
solidaxel
solidaxel's Avatar
Re: kinda wierd
This time of year I think they will both be working, there is a way to have them come on at different temps, but that will involve some homework!
LS 3 4L70E
Old 06-23-2014, 02:55 PM   #8
dman1982
dman1982's Avatar
Re: kinda wierd
thats how they are working right now, the low fan comes on when i start it, then the high fan will come on after it warms up, then when fully warmed up at some point they will both kick on, then just the high fan, i think they are working correctly
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-24-2014, 03:24 AM   #9
crazy longhorn
Fabricate till you "puke"
Re: kinda wierd
I am not a wiring guru....my fans are not hooked to computer. I run a painless relay, & power 2 -14" fans, That are mounted to a steel shelf. They worked on my 383, & still work on my 5.3? Wax on 205/Wax off 195? If you don't have the relay, or diode, I agree, you have power feed, until the alternator stops charging? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
