Neutral safety switch adjustment..how to?
I think I need to replace the neutral safety switch on my '70 C10. My first time doing it, I dont know how to adjust it. Looks like an OEM replacement at the bottom of the column.
Thanks fellas, -Andrew |
#2 | |
The Older Generation
Re: Neutral safety switch adjustment..how to?
There are two small hex head screws that hold the NSS to the column. Use a 5/16", socket to loosen them. To adjust you just loosen the screws and the NSS will slide from side to side. It doesn't move much but it will be enough to adjust it. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-02-2017 at 08:52 PM. Reason: Double checked socket size abd changed text |
And how do you know if your adjusting it right? What do you want to adjust to? I'm replacing it because every once in a while, it won't start. Iv got all electrical power, but won't crank, won't click, nothing. Then let it sit for about 30 minutes and it starts right up.
![]() Join Date: Sep 2013
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
I've been reading up on the NSS cos I need to re-wire mine. Some one suggested that to adjust for your reverse lights (which are also wired into the NSS) You start with what LockDoc suggests then have someone stand behind the truck, with key in the on position but not running put shift into reverse. slide the NSS back and forth to where the reverse lights go on or off. Find the mid point where they come on and tighten the screws. This might solve your problem. Making sure the wire contacts are all clean and tight should also be considered. Hope that helps and good luck.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
#5 | |
LockDoc
Rusty Nuts
When i added mine to the column, i put the gear selector in reverse and adjusted it for the reverse lights to come on and then i tighten it up. It took a few times because when i would tighten it up the lights would go off, but i finally got it, and then put it in park and seen if it would start and it did.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
Thanks fellas, I'll do it tonight.
Just a reminder - make sure to use the star washers (if they're not integral to the bolts, which I don't think they are) and proper torque. Otherwise 3 years from now it'll slide, you'll forget you ever touched it by then, and your truck will inexplicably not start...
#9 | |
![]() Join Date: Feb 2011
Thanks in advance!
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
LocDoc, My 70 C10 starts in Park but not in Nuetral and BU lights work in Nuetral but not in Reverse. I believe my NSS needs adjustment. I read your comment about using a 1/4 socket, nut driver or 12 pt wrench. Unfortunately I cannot seem to get any tool on the head to loosen the screws. Any other ideas?
1970 C-10 CST, LWB, 402/400, A/C |
#11 | |
Yep, It takes a 5/16" socket. I changed my previous post. LockDoc
Thanks Leon. I'll try a 5/16" socket tomorrow. I was also thinking I would,try a deep well socket with the 1/4 ratchet.
Based on info I gave you. Do you agree that NSS switch is ok but just needs adjusted?
#13 | |
LockDoc
#14 |
I literally just did this last week on my truck because back up lights not working right.
Thenubit it by the base of the column just before it exists the firewall. Make sure your selector lines up over P R N D etc. that's adjust under hood Then slightly loosen the bolts. The drivers side is about impossible to get 1/4" drive 5/16" socket on. Once loosened slight give is a few love taps with hammer. It slides around the column. Soak it good with contract cleaner too. Put the truck in reverse (key on of course). Then have move it until back up lighted are on. The check starting in park and nuetral. Wiggle the column in both park and Nutruel and try starting a few times. Tight screws and you're all set Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
#15 |
Thanks guys for input. Turns out my screws were 1/4". I used a universal swivel attachment on a deepwell socket with my 1/4" ratchet and got those two screws loosened up. Rotated the NSS until BU lights worked in R instead of N. now truck starts in P and N!
Thanks again for input. I would never had I had to rotate the NSS to calibrate the shifter! Learn something new every time I go on website!
#16 | |
LockDoc
#17 |
My '72 did the same thing, out of adjustment so B/Us didn't work and wouldn't start in neutral. The truck was idling low in drive at stop lights when I first had it running last summer. I was popping it into neutral to bring the idle up. I wonder how many people I gave panic attacks to before I realized the B/Us were lighting up. Probably revved it some, too!
![]() I had an issue a couple years ago with intermittent starting. It was the NSS, which was the last thing I checked.
