DIY Blasting Cabinet. Anyone build one recently??
Having heard the prices to blast a stripped C10 cab...... £310.00 for bladting alone at mates rates, I have decided to build a cabinet myself (as long as I can find a pair of those thick looooong gynaecological gloves you use to hold stuff with)
A 20 gallon resevoir is around £120.00 delivered and I have a 100liter/150lbs per square inch Broom Wade compressor. Should work OK. I will Goigle it in a bit too, to see just how easy, or not, it is to build a cabinet. Just looking for tips before I figure it out by trial and error. Thanks.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
Here is a quick search of what I found.
http://www.midsouthmakers.org/2010/0...ki-by-jwoodjr/ http://www.hainesengineering.com/rha...ndblasting.htm http://www.customfighters.com/forums...ad.php?t=23694 http://tehpear.com/blog/index.php?startrecord=460 http://www.midsouthmakers.org/2013/0...first-results/
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
![]() Join Date: Aug 2010
Re: DIY Blasting Cabinet. Anyone build one recently??
Do you want a blasting ROOM, or a simple cabinet? Small parts are easily handled with a big cardboard box like for a dishwasher. Cut an opening in the top toward the front and lay a piece of glass over it for a window, get gloves like you mentioned stapled over hand holes cut in the front, poke a hole high in the back for a shop vac hose, a hole in the side for an air line, and one on top somewhere for a light bulb, and that's it. Media bucket inside with a siphon pickup works great for getting the small/medium job done. Best thing is you can throw it away (the box) when your done so it's not hogging valuable space in the shop when you don't need it. I've done this several times for many projects over the years, but can't seem to find a picture. Trust me, it works well for cheap!
That sounds great.
Thanks for sharing. My cab is fine but Martin needs his to be decently blasted etc.
#5 | |
I made a "mini-garage" that serves 2 different purposes. I use it as my large blasting cabinet and I also use it as a cover for my engine. Allow me to explain. I wanted to protect my engine from the weather while I had the hood and fenders off. I have a minimal storage space, so keeping the engine on the frame seemed the safest and most logical. After I restored and painted the engine (all done outside) I set it back on the frame. So my "mini-garage" does 2 things. It keeps the engine clean and I also use it as a blasting cabinet so I can re-collect blasting media and use it a second time, thus saving a bit of money. It's a simple 4 sided box. The small wheels keep one end just an inch or two off the ground and the other end has short legs to do the same. This allows ventilation. It's wide enough to straddle both front tires. To use as a blast cabinet, I roll it into the yard and turn it over 90 degrees. Most of the blast media can be captured and collected with a broom. It can be moved by 1 person with one hand and I can roll it anywhere in my yard all by myself. The original flat top (pictured) collected rainwater, so I modified it by placing a 2X4 beneath the center to give it a gentle curve left to right so the water runs off (sorry - no picture of that, but you get the idea). Materials cost about $65. The last 2 pics show the engine under plastic with all the front body panels off. I am able to cover everything from the firewall forward with the "mini-garage". Necessity is the mother of invention, humble as it may be.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Who Me?
Nuttin wrong with that!!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Wow! That was a great Idea, Thanks for the tip
![]() Join Date: Aug 2008
A country boy can survive
![]() Join Date: Mar 2011
I use an 8x8 foot picnic canopy with plastic sheeting around the sides and a tarp underneath to catch the blast media for re-use.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
Now that Monile carage cabinet idea I do like a whole lot.
I have access to an intermittent supply of Chinese build packing crates from a Stainless steel company down the road who fit out commercial kitchens and bring in large machines. May even find a complete unit ready made. Thanks for the detailed description.
PS.......
I picked up a great solution to the loooooong Gynaecological gloves problem on another forum. Take a regulap pair of long gauntlets (prefersbly rubber fingered) and sew them to the cut off legs of a pair of denim jeans and then staple to the handling holes of a cabinet. These forums really do rock with clever helpful people.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Some great ideas here in this thread.
. It reminded me of this brilliant fresh air mask idea. http://67-72chevytrucks.com/vboard/s...47#post4470447
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#13 |
Best part of forums to ne is friendships and shared knowlege.
#14 |
78K & 79C Jimmys
interesting idea,gotta make one soon
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#15 |
I saw one where I guy used a large tupperwhere container,put a piece of glass on top and cut 2 holes for his hands
#16 |
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
