06-30-2014, 02:07 PM | #1 |
'67-'72 Lower Control Arms
Are the C10 1/2 ton control arms the exact same configuration ie, measurements, thickness, shafts & ball joints as a C20 3/4 ton? If not, what's different?
06-30-2014, 05:15 PM | #2 |
Re: '67-'72 Lower Control Arms
Ball joint hole is larger on the 3/4 ton
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
06-30-2014, 05:16 PM | #3 |
the shaft that attaches the LCA to the crossmember is bigger on C20.
06-30-2014, 06:54 PM | #4 |
Thanks for the reply guys! So am I to understand that by using the larger C20 parts, one can adapt the C20 arms to a C10 suspension?
06-30-2014, 07:03 PM | #5 | |
67-72 parts collector,…
C10 spindles require C10 balljoints,... and they only fit C10 a-arms. You could convert your C10 to a C20 8-lug truck,... by using C20 lower a-arms.
06-30-2014, 09:02 PM | #6 |
Gotcha!
