07-02-2014, 10:30 PM | #1 |
TH350 issue
OK....so I installed my flex plate backwards, so I need to get it out and turned around.
SBC and TH350 are installed. Never done this before. What is the easiest method? Remove cross member and lower it out the bottom? Pull motor? Thanks in advance!! |
07-02-2014, 11:00 PM | #2 |
All about them K’s
Re: TH350 issue
If it were me if probably pull the crossmember and slide the trans back far enough to get it apart. To me it's easier to only worry about getting the dowel pins in the block lined up to the trans than it is to fight the motor mounts and dowel pins both. Others may suggest differently but this is my personal preference.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-02-2014, 11:22 PM | #3 |
Re: TH350 issue
Get two 3/8 NC bolts about 6 or 8 inches long to put in the bottom two bolt holes. That way you can slide the trans back with the jack far enough to reach between the flex plate and torque converter with the wrench you use. You can break them loose with a torque wrench or breaker bar and then run them out with a ratchet or maybe even your fingers. When you get the flexplate back on right and have the bolts torqued you just slide the trans forward on the long bolts, install the four other bolts and tighten them and replace the long ones with the ones that go there. Beats the daylights out of trying to fight it back in place laying on your back.
07-03-2014, 02:37 AM | #4 |
Re: TH350 issue
Stealing that trick
GOD BLESS AMERICA! |
07-03-2014, 06:00 AM | #5 |
Old Heap Driver
Re: TH350 issue
Mr48Chevy is correct, it would be hard to top that method, I've used it many times.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
07-03-2014, 06:35 AM | #6 |
Re: TH350 issue
A couple of tips to add to Mr48Chev's trick: Sometimes you'll only have enough room to slide the trans back a couple of inches. A belt tensioner tool and short socket will fit into a smaller space than most torque wrenches or breaker bars and typically have longer handles, too. You might have to grind a socket shorter because tensioner tools rarely come with 9/16" or 11/16" sockets. Also, six point sockets are less likely to round the bolt head than 12 point. You don't want to round the flexplate to crankshaft bolt head.
07-03-2014, 09:15 AM | #7 | |
Re: TH350 issue
Thanks soo much!! |
07-03-2014, 01:18 PM | #8 |
Re: TH350 issue
old school trick for any tranny/bellhousing install, works with manual trans bolts into the bellhousing too.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-08-2014, 10:44 PM | #9 |
Re: TH350 issue
OK, so I pulled the tranny back and R & R the flexplate in the correct orientation. I bolted the tranny back up and have about 3/8" of space between the flex plate and the bolt pads for the converter. Is it OK to slide the converter back out to the flex plate and bolt up?
07-08-2014, 10:47 PM | #10 |
Re: TH350 issue
yep i just did my install same thing mine was more like 1/4 away but should be fine
11-29-2014, 11:58 PM | #11 |
Re: TH350 issue
I need to replace my flexplate also. When sliding the trans back do I need to disconnect the tranny lines etc? Does anyone have a step by step instruction on what to do first?
Thanks |
