Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 07-06-2014, 10:35 PM   #1
LEEVON
LEEVON's Avatar
"Black Betty" 1995 GMC Reg. Cab Sport Side
Had to scratch an 88-98 itch I've had for awhile...so I picked up this this granddad special to by my DD and shop truck. She has 141k easy miles, comes with the dainty 4.3L but has power windows and locks. I haven't formulated a plan, but short term will be stash the topper somewhere, throw on some 88-98 rallys with new tires, lower 4/6 and go from there. My end game is to put an LS engine in this one
This will be a slow upgrade/build. Here are a few of the seller's photos.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 07-06-2014, 11:16 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: "Black Betty" 1995 GMC Reg. Cab Sport Side
Very cool truck.
My opinion,... The 88-98 trucks are one of the best driving trucks you can own.
Congrats.
Keith
Convert to disc brakes.
Old 07-07-2014, 02:18 AM   #3
Hankster
Hankster's Avatar
Good looking truck, for sure.. can't wait to see it with an altitude adjustment.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 07-09-2014, 10:48 PM   #4
LEEVON
LEEVON's Avatar
Very cool truck.
Congrats.
Agree, they are so smooth on the highway...thanks!
Me too! Won't be long!
Old 07-09-2014, 10:51 PM   #5
LEEVON
LEEVON's Avatar
I performed her first mod, a camper shell delete.
What do ya'll think about black wheels and stock center caps? I have a set of 88-98 15x7 steel wheels ready to go. Kind of a sleeper look, like the pic below except keeping the trim. It will have more effect when the 5.3L is swapped in.
Old 07-09-2014, 11:00 PM   #6
Hankster
Hankster's Avatar
I like the look of the black wheels. I say go for it!!
Current Build
Old 07-18-2014, 09:14 PM   #7
LEEVON
LEEVON's Avatar
The truck is really solid, front suspension is tight, no leaks and clean underside. It is a real highway machine, super quiet, straight and smooth at 75mph. It did come with two issues besides the fact the 4.3L can't get out of it's own way . The temp gauge read just above 100 degrees and the ABS light is on. So yesterday I replaced the thermostat which was hung open. I suspect on of the wheel speed sensors is bad so that's next. Today I cleaned and painted the steel wheels and mounted a set of new Cooper 225/75/15's. Then I scored a set of NOS GMC center caps on Ebay. I also ordered a 2002 master cylinder and adapter fitting for increased brake pedal response.
Next up, 4/6 drop.
Old 07-19-2014, 04:29 PM   #8
Hankster
Hankster's Avatar
Can't wait to see the wheels with the drop!
Current Build
Old 07-19-2014, 08:21 PM   #9
LEEVON
LEEVON's Avatar
Good because I'm not showing the wheels without the center caps and drop! The truck looks very ugly at the moment!
Old 07-19-2014, 08:23 PM   #10
LEEVON
LEEVON's Avatar
I did the master cylinder swap and flushed all the old fluid. It's a nice improvement to the pedal feel. The brakes will be even better with a set of power stop drilled and slotted rotors.
I'm going to order the drop parts this week.
Old 07-20-2014, 12:35 AM   #11
Hankster
Hankster's Avatar
You slipped up and showed it without centers.. hahah. What are you gonna run for center? Astro van center would look GOOOOOOD!
Current Build
Old 07-21-2014, 11:58 AM   #12
88copperhead
88copperhead's Avatar
Really good looking truck. On the brake master swap do u need adapter and if so do you have a part number handy.
88 chevy W/T carb'd 400/t400 5/6drop 95 chevy burb 5.7/auto 3/6 drop 65 chevy swb 305/250 3/5 drop disc p/b work in progress
88copperhead is offline   Reply With Quote
Old 07-21-2014, 03:16 PM   #13
joecool
Looks real good!
joecool is offline   Reply With Quote
Old 07-21-2014, 09:35 PM   #14
LEEVON
LEEVON's Avatar
Thanks and yes, you only need a 9/16-18 female to 1/2-20 male adapter and a little tweak in the lines. AGS part number BLF 26C or Edelman 258306. Got the master cylinder from Napa and the adapter from O'Reilly.
Originally Posted by joecool View Post
Looks real good!
Thanks!
Old 07-21-2014, 09:43 PM   #15
LEEVON
LEEVON's Avatar
The GMC center caps came sooner than expected (ordered Saturday and shipped from California to Missouri via USPS...one business day...I was flat out astonished). They were NOS in the original packaging with the black lug nut covers. I also had to get some of the external thread lug nuts.
Old 07-21-2014, 09:47 PM   #16
LEEVON
LEEVON's Avatar
Also ordered the lowering stuff today. I went with a Belltech flip kit and notch through Summit for the 6" rear drop. It comes with shock relocators which are a must and I like their notch design. For the front, I went with McGaughy's spindles from Grunion Fabrication as usual.
Old 07-24-2014, 08:41 PM   #17
jb1016
"Oh well, it's a driver."
jb1016's Avatar
I'm in. Looks like a great truck to start with and your trucks always turn out so nice. I think it needs more tire to pull off the steelie look, but that's just my $.02. And a little black spray-bomb on the wheel weights would help too.
Old 07-25-2014, 12:59 AM   #18
LEEVON
LEEVON's Avatar
Thanks! I hear ya on the weights, I was even thinking about re-balancing with some beads because they took more weight than I hoped. But hang tight on the tire size/look, another few days and it will come together. I was very deliberate picking those out to go with the 4/6 drop. Stock 235's are too big and rub fenders. The 225/75/15's look small at stock height but they're really only about 1" shorter and .5" narrower.
Speaking of the drop, I got the rear flip and the c-notches mostly done tonight. It was the first time I've ever had a fully equipped shop for lowering a truck so now I'm spoiled by lifts, air, bright lights, etc. The underside of the truck is super clean too, bed looks like it was never dirty. Crazy how clean it is, and not a single dent. I should be wrapping up Monday or Tuesday when my spindles get here.
Old 07-25-2014, 11:49 AM   #19
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Just an FYI, your "Black Betty" thread link in your signature points to the "Rebound" thread.
killthewabbit is offline   Reply With Quote
Old 07-25-2014, 12:03 PM   #20
JWall
Frequent Flyer
JWall's Avatar
I've said before you always have the cool trucks & now you all the cool toys in the shop too... If I was a little closer you'd find me loitering at your shop!
The truck is looking good... looks like a very slick one!
- Justin
1 Owner 1976 SWB
Old 07-25-2014, 01:53 PM   #21
LEEVON
LEEVON's Avatar
Fixed. thanks!
Thanks! But think you're giving me too much credit because your trucks are killer! I am going to have a small gathering this fall...need to hurry and pick out a date. If you're interested.
Old 07-26-2014, 11:41 AM   #22
JWall
Frequent Flyer
JWall's Avatar
Let me know the date when you figure it out.
I might try to make it. I have family that way too.
- Justin
1 Owner 1976 SWB
Old 07-26-2014, 12:13 PM   #23
DroppedAsAChild
DroppedAsAChild's Avatar
Sweet Build.
1999 OBS Gmc Sierra ECSB Classic 1500 2wd-The Show truck
(Black/Greystone metallic 2 tone)
1999 OBS GMC Yukon 4dr 2wd-Daily Driver/Toy (White)
1990 OBS GMC Sierra ST RCSS 2wd-100% Factory Original
(Crimson Red/Metallic Silver 2 tone)
1997 OBS Chevrolet Silverado ECSB 2wd-Pops Daily/Tow Pig (White)
DroppedAsAChild is offline   Reply With Quote
Old 07-26-2014, 08:33 PM   #24
LEEVON
LEEVON's Avatar
Will Do!
Originally Posted by DroppedAsAChild View Post
Sweet Build.
Thanks!
Old 07-26-2014, 08:36 PM   #25
LEEVON
LEEVON's Avatar
Got the rear drop stuff done today. I could have taken this a lot further by fabricating boxed-notches and relocating the upper shock mounts but I just don't have the time. The belltech notches are a nice quality piece. I was on the fence about welding them in but when I was in the middle of it all a friend stopped by who is a structural engineer stopped in by chance and confirmed some of my thoughts, so I ended up adding some welds. Note the rear lower shock relocators, these are key to achieving a decent ride quality. Glad this is all done, it was dirty job in the heat. The front spindles should be here Monday!
