Hello
Hey new to the site but not new to forums. I have a question if anyone could answer them, Where can I find a driveshaft slip yoke that accepts a 1330 u joint, 1.5" shaft diameter, 6 3/4" inch from bearing cap center to end of yoke (without dust cap), and is 16 spline? Its been a needle in a haystack search the last week and a half.
Little about my truck. Its a 1978 GMC Sierra 1/2 ton. My dad bought the truck from his boss for $100 when i was about 10 years old with a bad rod knock. Helped my dad pull the engine and rebuild it which was a mild build, stock bottom end, mild cam, aluminum intake, stock heads and a Holley 4 barrel. Drove it like that for quite a few years then a couple valves burnt in the head. This time was a bigger build than before. Had the block machined and bored out to make it a 383, Edelbrock performer series top end (carb, intake, cam), went with the aluminum performer rpm heads. Had a lot of fun with it for a few more years. Then my dad had lost his job two years ago due to the company he worked for going bankrupt and I had a lot of health problems at the time and he sold the truck to help take care of some of the bills. About two months ago though I was able to track it down and buy it back! I don't think I've ever seen a bigger smile on his face (besides giving him his first grandchild). Here's a picture of it from a couple weeks ago, minus the drive shaft. Had a little fun leaving work the one night ![]() ![]()
1978 ![]() |
Re: Hello
Hello. Welcome to the forum. You're among friends here.
You must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
Re: Hello
Thank you very much! I was looking through a lot of rules and guidelines on here and couldn't find that. Ill take a look at the supporting member and see how much it is.
1978 ![]() |
Re: Hello
Re: Hello
I know a little about Indy. That plant is/was not far from what is now Lucas Oil Stadium, a little ways east. Correct?
Re: Hello
Re: Hello
I have the original build sheet ill have to check tonight if it was from that plant or not.
1978 ![]() |
Re: Hello
