Old 07-15-2014, 12:34 PM   #1
crowdaddy
crowdaddy's Avatar
3 point seat belts 1964 c-10 truck
Seat belts are a must in my family, and so I'm looking for others that have put regular seat belts in their trucks. I've heard s-10 belts work well, but I would like to hear about people that are using them or other 3 pt belt systems. I don't believe in 64 there were any pre drilled spots for the belts yet. Any ideas pictures would be helpful.
crowdaddy is offline   Reply With Quote
Old 07-15-2014, 12:38 PM   #2
TypeSL2
Re: 3 point seat belts 1964 c-10 truck
I too am curious about this as well. I recently bought some seats that have the 3 point belts all contained in the seat, but would like to open my options for if I decide to use a different seat later.
James
TypeSL2 is offline   Reply With Quote
Old 07-15-2014, 01:06 PM   #3
1963c-10
1963c-10's Avatar
A good thread on installing 3 point belts in a 64-66 cab. I believe 66 was the 1st year with the 3 point belt provision.
Link: http://67-72chevytrucks.com/vboard/s...d.php?t=564865
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-15-2014, 01:14 PM   #4
64fleetside
I used belts from a 98 Silverado.
64fleetside is offline   Reply With Quote
Old 07-15-2014, 01:20 PM   #5
crowdaddy
crowdaddy's Avatar
Thanks guys, I'm getting educated, checking it out!!
Old 07-15-2014, 08:12 PM   #6
corvettejim1968
corvettejim1968's Avatar
66 was the 1st year seat belts were standard. im pretty sure LMC has the 3 point harness . mine are just lap belts but here are some pics of what i did.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 07-16-2014, 05:08 AM   #7
Woogeroo
Wink Re: 3 point seat belts 1964 c-10 truck
Juliano's
For more ideas and options see the Seat Belts category of
your 60-66 FAQ Index.
-W
NOTE : if this link changes in the future, look for the sticky at the
top of the 1960-66 Message Board.
Woogeroo is offline   Reply With Quote
Old 07-16-2014, 12:52 PM   #8
crowdaddy
crowdaddy's Avatar
Nice job corvette jim…..I'll be looking in those areas for drilling…..
Old 07-16-2014, 07:46 PM   #9
corvettejim1968
thanks if i remember correctly there was a spot weld at the point i drilled into. made it easy. and i bought the spring wind up on year one web site under impala. its the same seat belt option for our trucks according to my brochure.
Old 07-16-2014, 08:25 PM   #10
AcampoDave
AcampoDave's Avatar
Got these from Juliano's Interior Products. They come with a nice set of anchor plates with the nut welded on. For the shoulder harness, I drilled the hole using and old socket for a drill stop and then taped the anchor to a stick and fished it up there till I saw the nut, then threaded in the bolt. I did remove my tank to facilitate installation on the drivers side.
AcampoDave is offline   Reply With Quote
Old 07-16-2014, 08:42 PM   #11
PGSigns
PGSigns's Avatar
I got mine from here. http://www.andoauto.com/Truck-R.htm Very nice and have been working well for the last several months since I got them in.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-17-2014, 12:03 AM   #12
TopFuel1966
TopFuel1966's Avatar
Juliano's
TopFuel1966 is offline   Reply With Quote
Old 07-17-2014, 01:35 AM   #13
AcampoDave
AcampoDave's Avatar
Top fuel 1966 your interior is beautiful, and wow 1 piece side glass to boot!
Old 07-17-2014, 05:54 PM   #14
crowdaddy
crowdaddy's Avatar
Nice seat belts everyone! I'm looking at the placements, thinkin about where to get them and anxiously awaiting my 230 rebuild and the return of my truck.
Old 07-17-2014, 05:56 PM   #15
crowdaddy
crowdaddy's Avatar
Ampco dave, nice shot of the high point in the cab and tip about the tank. I would have asked that question eventually, you guys don't miss nothin'.
Old 07-17-2014, 09:22 PM   #16
66BigBackWindow
Wow, these all have great info. I will look back on this when I redo mine.
66BigBackWindow is offline   Reply With Quote
Old 07-18-2014, 11:43 AM   #17
TopFuel1966
Thanks. It looks better since the photos. The white inserts in the door panels went away. The white worked with the original beige but not so with the red IMO.
