Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 07-15-2014, 04:53 PM   #1
truckeez
Little fenderless Bad Boy
I got an ole pile of stuff out back, i think ill mess around with.
truckeez is offline   Reply With Quote
Old 07-16-2014, 06:26 AM   #2
G-10Assembly
Re: Little fenderless Bad Boy
What year would this cab be?
G-10Assembly is offline   Reply With Quote
Old 07-16-2014, 03:51 PM   #3
truckeez
The "pirate sword " style beltline design identifies it as a 34-8 (but mid thirties internationals look virtually identical to the 34-early 36 gm "high cab" cabs) all the body panels screwed into a wood frame structure-and the roof was more square looking with a little visor above the windshield.
Late 36 started the rounded "turrent top" smooth look which has maybe 1.5 inches lower roof line. All the panels were spotwelded to a really flimsy steel frame structure ---except the 36 still had wood posts where the door hinges mount--if you get one of those first thing you should do is put some square tubing in where those wood posts are. There are a few other differences between a late 36 and the 37-8 but they pretty much look the same.
