Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-15-2014, 09:59 PM   #1
1774btcrew
1774btcrew's Avatar
I have too many tach clusters! 3 for sale
Well, I have been buying tach clusters for several years and have only sold a one here and there. I don't need all of them and have come to the realization that they take up a lot of room and are hard to store carefully. 2 of these are in really outstanding condition and they are priced accordingly. They are high priced but they are worth it. The 3rd is rougher and priced what I feel is cheap. I do have 2 cut tach pigtails and one complete uncut. If someone can school me on which harness goes with each cluster I MAY have other complete harnesses. These will be described from top to bottom in the picture.
THIS HAS BEEN SOLD! Numbers 2 and 3 are still available. THANK YOU WALTER! 1) Is a SUPER clean cluster for the 78-80 or so trucks. It will fit other years if you can repin your plug. It has an electric voltage gauge and the blue stripe tach and speedometer. The great thing about this is the white plastic gauge housing has been replaced with a newer one that isn't brittle and has NO broken tabs. This is probably as nice of a used tachometer cluster you could find anywhere. I paid a lot for this as it was part of a package deal and I wanted the other NOS parts the seller had. I need to recoupe my investment. I want $325 for this not including shipping.
2) Is a really nice 80 and newer or so cluster with the small fuel gauge in the tachometer face. I also replaced the white plastic gauge housing on this with a super nice one. Considerable time was spent cleanly fitting the gauges into this housing. The printed circuit is nice on this one as well as the clear lens. These are hard to find. I want $325 for this not including shipping.
3) This was bought a while back from a swap meet. It is also for the 78-80 or so trucks. It will fit the other years if you can repin your plug. Gauges are clean and circuit board is nice. The gauge housing is rough and is missing the outer left mounting tab and the upper right mounting tab(I will include an upper right mounting tab from a different cluster so you can epoxy on if so desired.) Price on this is $125 not including shipping.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 07-16-2014, 09:09 AM   #2
68post
Re: I have too many tach clusters! 3 for sale
Question, is the #2 cluster from a diesel ? ( tach only goes to 4,000, and oil pressure goes to a high of 100 psi )
68post is offline   Reply With Quote
Old 07-16-2014, 11:27 AM   #3
1774btcrew
1774btcrew's Avatar
It was out of a diesel. The last one like this that I sold went into a gas truck but I am not sure what was involved.
Old 07-16-2014, 10:51 PM   #4
68post
Thanks, it would work in my gas truck if it only went to 5,000 rpm.
Old 07-17-2014, 09:56 AM   #5
1774btcrew
1774btcrew's Avatar
I have had two of these and they were both 4000 RPM tachs. I have seen the 5000 ones but never found one myself
Old 07-21-2014, 01:34 AM   #6
1774btcrew
1774btcrew's Avatar
ttt
Old 09-17-2014, 01:06 AM   #7
1774btcrew
1774btcrew's Avatar
ttt
Old 09-24-2014, 09:45 AM   #8
1774btcrew
1774btcrew's Avatar
ttt
Old 09-24-2014, 09:40 PM   #9
CircusWagonJim
CircusWagonJim's Avatar
Could you clarify on the earlier clusters why those are not '76-'77 because both my '76 Blazer and Truck have that style face gauges original. Senn many other unmolested '76s with that style gauge as well. Would be interested in the third cluster if it works in my '76 Blazer.
CircusWagonJim is offline   Reply With Quote
Old 09-24-2014, 09:52 PM   #10
1774btcrew
1774btcrew's Avatar
77 and earlier had a mechanical oil pressure gauge. These have an electric oil pressure gauge.
Old 09-24-2014, 10:25 PM   #11
CircusWagonJim
So it doesn't use the same plug is what you said earlier? I didn't understand.
Old 10-14-2014, 11:29 PM   #12
1774btcrew
1774btcrew's Avatar
ttt
Old 10-15-2014, 03:05 PM   #13
Chaplain
Chaplain's Avatar
Chaplain is offline   Reply With Quote
Old 10-22-2014, 01:09 AM   #14
1774btcrew
1774btcrew's Avatar
Old 10-22-2014, 11:38 AM   #15
gmachinz
Jim, unless you want to add the sender lead from one of the 78-79 tach clusters to an electric sending unit, you are better off finding a 76-77 style.
73-75 amps and mech. oil
76 changed to volts, different gauge face style
78 changed to electric oil and got a yellow/orange redline on tach
80 changed to newer style gauge face, 85 mph
82 dropped the red line color band
I am not certain on the various C50/60 series trucks since I don't find hem very often.
gmachinz is offline   Reply With Quote
Old 10-22-2014, 04:00 PM   #16
american revolution
american revolution's Avatar
will this work for an 80 blazer?
american revolution is offline   Reply With Quote
Old 01-11-2015, 04:40 AM   #17
Chaplain
Chaplain's Avatar
Great seller
Old 01-15-2015, 02:40 AM   #18
Gregski
Post Whore
Gregski's Avatar
I am looking for a gauge cluster for my 1974 GMC 1500 V8 manual or just for the blue housing that accomodates the large tach and the small fuel gauge, would one of these work, would you have just the housing for sell
Gregski is offline   Reply With Quote
Old 01-15-2015, 08:07 AM   #19
Chaplain
Chaplain's Avatar
Get ready for some good feedback. I've received and found plenty of insight since I first started my search for a compatible cluster.
http://www.67-72chevytrucks.com/vboa...d.php?t=656046
Old 01-15-2015, 10:57 AM   #20
1774btcrew
1774btcrew's Avatar
Walter, I hope all is going well. I am keeping my eyes open for the other things you need.
Old 01-15-2015, 10:59 AM   #21
1774btcrew
1774btcrew's Avatar
I responded in my post for just the tachometer but I also have 2 early tach clusters. I have quite a few of these in varying condition
Old 01-15-2015, 11:20 AM   #22
Chaplain
Chaplain's Avatar
I told you...
Old 01-15-2015, 11:33 AM   #23
Gregski
Post Whore
Gregski's Avatar
Brilliant, thank you for the link
Old 01-15-2015, 11:45 AM   #24
Chaplain
Chaplain's Avatar
Yep
