Old 07-18-2014, 09:34 AM   #1
funkj62
62 bagged Kneekocker project
I'd like to introduce myself, my name is Jeff and I have enjoyed browsing the build section for a while. I'm a retired electrician and converted into a body shop man for pleasure and something different.
Recently I purchased a1962 c-10 cab sitting in the weeds of my brother in-laws for $100 and decided to make a bagged project out of it. My goal was to build a complete frame and suspension and have a working rolling chassis before I mount the cab.
Here are some pic's of the beginning and start of my project.
funkj62 is offline   Reply With Quote
Old 07-18-2014, 09:48 AM   #2
1963c-10
1963c-10's Avatar
Re: 62 bagged Kneekocker project
Welcome to the forum and nice fab work. Looks like your off to a nice start already!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-18-2014, 10:10 AM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Welcome aboard! X2 on Nice fab work.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-18-2014, 08:27 PM   #4
funkj62
Thanks guys appreciate the nice comments.
Old 07-18-2014, 10:19 PM   #5
Ta2Don
Ta2Don's Avatar
aboard…
Wow, Looks like a Great Start...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 07-20-2014, 03:45 PM   #6
funkj62
Originally Posted by Ta2Don View Post
aboard…
Ta2Don I browsed through your build thread, could you give me the rundown on what master cylinder/brake booster you used? Very clean installation.
Old 07-20-2014, 03:50 PM   #7
funkj62
For the guys looking for easy made ball joint plates Speedway Motors offer these for $4.99 each. The only down fall is they are only wide enough to incorporate a coil over shock. They just were notwide enough formy installation so I had to fabricate my own.
Old 07-20-2014, 04:24 PM   #8
funkj62
I incorporated my upper A-Arm mount also as my upper bag mount.
Here are my upper/lower ball joint plates after being cut out.
I'm using 1' x.156 wall tubing which already has an ID for direct tape to 3/4-16 rod ends.
Old 07-21-2014, 08:37 PM   #9
funkj62
Got all my ball-joint plates cut out.
Jigging and welding my lower A-arms
The dreaded job of tapping in rod ends.
Completed lower A-arm.
Old 07-26-2014, 12:31 PM   #10
funkj62
No progress to report, still waiting for the machine shop to finish drilling/tapping my cross shafts for my upper/lower A-arm mounts.
Once their completed I can finish the final fit and weldment of the front suspension and head toward the rear 4-link fab work,
Old 07-27-2014, 03:33 PM   #11
creep
Registered Loser
creep's Avatar
Nice work! Are you planning on running big wheels? smaller wheels probably won't work with those lower arms.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 07-27-2014, 04:04 PM   #12
funkj62
Small wheels, for the time being. I've done the geometry /math and it doesn't seem to be an issue with 15/16 inch rims. I have clearance for 40 degrees of turn radius, Im not looking for the performance of a Lamborghini.
Old 07-28-2014, 03:54 PM   #13
funkj62
Lmao.You had me second guessing my measurements, I checked this morning and I have well over 40 degree turn radius and plenty of clearance with 15'rim. The only problem I have found is somewhere after 43 degrees the spindle steering arm gets into the bag. I'm pretty sure 40 degrees will be plenty and I will have to weld on a stop/block. Props for having a good eye, most would have not second guessed it.
Old 08-20-2015, 07:34 PM   #14
funkj62
thought I would post some progress.
Old 08-21-2015, 11:56 AM   #15
Bomp
Bomp's Avatar
Lookin' good. Im in. Sub'd
Bomp is offline   Reply With Quote
Old 08-22-2015, 11:55 AM   #16
creep
Registered Loser
creep's Avatar
Nice!
