Old 07-18-2014, 02:32 PM   #1
swissarmychainsaw
Blown Fuses and General Wiring Nightmare
So I bought an awesome BURB (1973) but it has some (cough) wiring issues.
The most recent dilemma is that the Fuel Gauge stopped working (blown fuse); but now it blows the fuse every time. Too much jiggling on the last off-road adventure, I guess.
Now, before I go chasing down one frayed wire...
What do you suggest? Should I just replace the harnesses? There seem to be kits that might be less work than trying to "Fix" existing wiring issues).
I would also like to replace the glass fuse box with a modern blade type.
Glass fuses are a pain to deal with, are hard to see, and hard to remove!
This gives you an idea what I'm dealing with. The black chunky stuff is all over the place. It looks like melted plastic, and I have no idea what it is from.
You can see bare wires twisted together. I'm surprised any of the lights work!
swissarmychainsaw is offline   Reply With Quote
Old 07-20-2014, 10:55 PM   #2
zaccaglin
zaccaglin's Avatar
Re: Blown Fuses and General Wiring Nightmare
I see your first problem, quick taps, rip these razor blade wire cutter SOBs off and use true but connectors in there place. Those hings will ruin wires and cause shorts every time.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 07-21-2014, 04:54 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
I would repair what you have. I know that's tedious and not a very glamorous job, but at least it can be done a bit at a time.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-05-2014, 04:52 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
for sure,clean it all out
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
