Old 07-22-2014, 12:09 PM   #1
66LSx
66LSx's Avatar
Passenger Side OEM Radiator Hoses
Guys,
1966 C-10
5.3L LM7 Vortec (LS)
4L60e
Passenger Side Radiator inlet/outlet 1-1/4 & 1-1/2" dia
Curious on what any of you guys are using for radiator hoses both upper and lower. (Part Number/Brand) I think the lower hose can be just a normal '2004 Silverado' lower radiator hose that is trimmed a bit. The upper is were I'm at a loss. What is everyone else using when you have a PASSENGER SIDE upper radiator inlet?
I figured with the width differences not being outrageous..... someone/anyone with an LS swap radiator (griffin, entropy etc) will have some input hopefully as to an OEM looking hose (no corrugated flex) that looked/worked good for them.
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 07-22-2014, 09:03 PM   #2
Mayfield
Re: Passenger Side OEM Radiator Hoses
Upper gates 21439
Mayfield is offline   Reply With Quote
Old 07-22-2014, 09:05 PM   #3
Mayfield
Lower Gates 20687
Old 07-24-2014, 12:13 PM   #4
littlevictories
99% sure those are the hoses I used ^
I am sure I used the stock lower from the donor truck and just walked around the back of the parts store until I found the right upper.
littlevictories is offline   Reply With Quote
Old 07-24-2014, 01:41 PM   #5
66LSx
66LSx's Avatar
Originally Posted by Mayfield View Post
Upper gates 21439 / Lower Gates 20687
littlevictories - 99% sure those are the hoses I used ^
To the both of you.... thank you!
1966 C10 SWB Fleet
Old 07-26-2014, 04:48 PM   #6
Hart_Rod
Hart_Rod's Avatar
Good info!
Hart_Rod is offline   Reply With Quote
Old 08-03-2014, 10:47 PM   #7
TypeSL2
What kind of radiator are you guys running in those pictures? I am running an eBay in mine and the inlet/outlet are in completely different locations. So these hoses won't work in my case. Just curious what other options are out there. Thanks and sorry for the partial thread jack.
James
TypeSL2 is offline   Reply With Quote
Old 08-05-2014, 08:25 PM   #8
66LSx
66LSx's Avatar
Just got my radiator in also... no chance these will work on a 60-66 C10
(Well the top one might work)
Any other ideas guys?
Right now I'm thinking 87 Buick Regal Lower and trimmed (remove the 90*) 97 Firebird Upper Both are correct diameters
Lower Upper (-90*)
1966 C10 SWB Fleet
Old 08-06-2014, 08:55 AM   #9
TypeSL2
That is exactly how mine looked. That is why I bought a straight thermostat housing. I am going to figure out a way to run hoses to what I have. If you find something to fit your setup, do post it up.
James
Old 08-06-2014, 09:36 AM   #10
47 Fasttoys
47 Fasttoys's Avatar
Can the lower outlet be removed from the housing? If so, can you modify it to turn it 90 degrees? I had to do this with my upper.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
