Old 07-22-2014, 07:08 PM   #1
mgchevyparts
mgchevyparts's Avatar
REF 2 whl drive Blazers/Jimmys with roll bar
My 75 has a factory roll bar, did previous years (73-74 2 whl dr) come with roll bars, including 69-72?
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 07-23-2014, 01:49 AM   #2
Irish1941
Irish1941's Avatar
Re: REF 2 whl drive Blazers/Jimmys with roll bar
Been a while but this what I remember about the roll bar deal...
'69-'72 No factory roll bar. 70 was first yr for 2wd.
Aftermarket dealer installed. Most likely Hickey.
'73-'74 was an option. GM parts book lists as available for '73-75 but can't find any info in sales lit about roll bars in '73-'74. Again pretty sure it was Vic Hickey suppling them.
'75 is yr it became standard but only if you ordered a hardtop. 2wd or 4wd.
No hardtop (they were optional) no roll bar. Didn't matter if plain or Cheyenne model.
There was no RPO code for roll bar.
Irish1941 is offline   Reply With Quote
Old 07-23-2014, 01:30 PM   #3
eighteenninetytwo
Where is the best place to get a roll bar for a 75 today? Any recommendations?
eighteenninetytwo is offline   Reply With Quote
Old 07-23-2014, 02:44 PM   #4
dragonball98312
dragonball98312's Avatar
I got mine off a 74 4wd blazer. Were they any different between 2 and 4wd? I know I've seen a 73 with a factory looking roll bar that was a different style than mine, so I'm guessing they made several designs?
dragonball98312 is offline   Reply With Quote
Old 07-23-2014, 06:08 PM   #5
eighteenninetytwo
I got one - or thought I had - from a 74 too. but when it came time to bolt it in, it didn't actually fit with enough room to have the interior wall of the bed fitted and get it into place. Quite annoying.
Old 07-23-2014, 07:15 PM   #6
mgchevyparts
U could purchase my Jimmy
Old 07-24-2014, 03:09 PM   #7
eighteenninetytwo
orr just the roll bar?
Old 07-24-2014, 06:46 PM   #8
mgchevyparts
Comes with a truck attached
Old 08-05-2014, 04:50 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
I hear you need to get the piece just under the floor? for proper attachment,not sure about all years.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-05-2014, 06:48 PM   #10
Irish1941
Irish1941's Avatar
Correct you are. The front leg bolt holes are in place on all trucks due to the rocker boxes being sealed up. No way to add a plate or nut and bolt it. The upper door jamb hole is also there behind the trim panel.
Old 08-07-2014, 01:22 AM   #11
eighteenninetytwo
so my 75 SHOULD have these holes already there for the bar. I need to look closely
