Old 07-31-2014, 04:03 PM   #1
trkfrk
trkfrk's Avatar
What clutch master-cylinder are you guys using for T56 trans
I am finally at the point where I can install my clutch system. Here is a master-cylinder I am looking at purchasing from EBay.
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en.
Anyone using this setup? Can you post pictures? If not, what are you using, and can you post pics.
Thanks,
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 08-01-2014, 12:22 AM   #2
Captainfab
60-66 Nut
Re: What clutch master-cylinder are you guys using for T56 trans
Within a couple weeks I should have my brake booster bracket with the hydraulic clutch conversion for the '67-'72's done. It will be basically the same as what I currently make for the '60-'62's. There is a link to the for sale thread in my sig line.
Old 08-01-2014, 01:19 AM   #3
conman585
conman585's Avatar
I thought this install looked good.
http://www.customclassictrucks.com/t...s_for_the_c10/
conman585 is offline   Reply With Quote
Old 08-01-2014, 01:39 AM   #4
conman585
conman585's Avatar
The actual part number of the MC was listed in a preceding article.
http://www.customclassictrucks.com/t...t/viewall.html
"To actuate the hydraulic throwout bearing on our Tremec, we’ll be using a Wilwood ¾-inch bore master cylinder (260-10282) coupled with their new billet reservoir (260- 12696)."
Old 08-01-2014, 08:55 AM   #5
Custom 68
Custom 68's Avatar
I will look tonight, I kept the box I believe incase I needed a new one later. It is a "cheapy" from Orielly
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-01-2014, 10:27 AM   #6
trkfrk
trkfrk's Avatar
Looking forward to seeing your finished producuct. Your brackets look great. Thanks!
Great article! I really like the looks of the Wilwood MC. My rear disk brakes are Wilwood and I'm really happy with their quality. Thanks for sharing. I am going to do some research on price/availability.
I don't mind cheap. Are you happy with the quality? How long have you been using it for? Can you post pics?
Mark
Old 08-01-2014, 11:57 AM   #7
1963c-10
1963c-10's Avatar
I used on of CaptainFabs hydraulic kits on my 63. Great product. I have a novak kit installed on the bellhousing.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-01-2014, 01:34 PM   #8
smoky02
Location: Sunny, Florida, some might call it South Alabama
Yeah Capt I'll be home on the 10th and can't wait to install your bracket
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 08-01-2014, 01:56 PM   #9
trkfrk
trkfrk's Avatar
Your engine bay looks great.. I will research Captainfabs kits. Thanks for sharing.
Please post pics when you get your bracket installed. Welcome back! I remember those long deployments. I did Desert Storm in 1991.
Mark
Old 10-25-2014, 07:59 PM   #10
dkauffman05
dkauffman05's Avatar
I am also about to begin my t56 install and will be looking for master cyl ideas.
dkauffman05 is offline   Reply With Quote
Old 11-13-2014, 03:25 PM   #11
joewell80
I am going to do a T56 swap this winter. I was thinking of trying to use the factory master cylinder from a 98-02 Camaro. I am not sure yet if it would work, the hose might not be long enough and it mounts on a angle.
Has anybody ever tried this before? I hate to start something and have nothing but trouble.
Thanks, Joe
joewell80 is offline   Reply With Quote
Old 11-15-2014, 03:27 AM   #12
littlevictories
like you said, it mounts on that angle, which sucks.
i've been squirreling parts for my 6mt swap and i'm gonna run with a tilton 7/8" mc
littlevictories is offline   Reply With Quote
Old 01-22-2015, 10:51 AM   #13
dkauffman05
Any updates on some installs ? I really like the wilwood in the first post but seems kinda pricey.
Old 01-22-2015, 01:20 PM   #14
smoky02
I decided since I had to pull the body off to do my suspension install that I would go ahead and clean the frame up. I'm about to start putting everything back together. So in the next few weeks I hope to have installed pics
Old 01-22-2015, 01:48 PM   #15
dkauffman05
What master are you using ?
Old 01-22-2015, 02:01 PM   #16
trkfrk
trkfrk's Avatar
I ended up finding a master cylinder at an off-road shop here in Vegas. It's made by JAMAR and was $100. I liked that it's all aluminum and black (no plastic). It should look good in my engine compartment
Mark
Old 01-22-2015, 02:05 PM   #17
trkfrk
trkfrk's Avatar
Engine compartment pic
Mark
Old 01-22-2015, 02:34 PM   #18
dkauffman05
That looks nice. Do you have a part number for it ? Hard to tell in the picture how you are mounting it to the firewall. I'm assuming your not running a booster.
Old 01-22-2015, 02:38 PM   #19
trkfrk
trkfrk's Avatar
When I get home I will check my receipt for part #. I'm using this master cylinder for my clutch so no booster.
Mark
Old 01-22-2015, 03:05 PM   #20
dkauffman05
Sorry. I'm on the hunt for a brake master and just got confused.
