Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-06-2014, 11:21 PM   #1
1963 c10
Frame lengths
Hey everyone I'm new to the site,
I picked up a1963 chev suburban.
Just wonder if the frame from the suburban
Is the same length as a swb or lwb.
From what I measured seems to be
Swb. Thanks in advance. I'm also trying to
Post picture but not having luck.
1963 c10 is offline   Reply With Quote
Old 08-07-2014, 01:41 AM   #2
pimpston65
pimpston65's Avatar
Re: Frame lengths
115wb, should have that info on the blue trim tag in cab on drivers panel by the vent
pimpston65 is offline   Reply With Quote
Old 08-07-2014, 03:08 AM   #3
spacedebris
Re: Frame lengths
Yeah I'm pretty sure that the swb is the same as the c10 burb/panel. 115" wheelbase.
Not to hijack the thread but a quick simi related frame question. Is there a difference between the 1/2 ton and 1 ton frames? Not suspension but frame itself. I'm a little concerned now that I found a 1/2 ton frame from a 63 P/U under my 60 1 ton panel. It does have the 1 ton suspension but I'm curios to know if there was a physical difference between the actual frames
spacedebris is offline   Reply With Quote
Old 08-07-2014, 05:54 AM   #4
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: Frame lengths
I used a long bed frame and cut it down to the 115" short bed length and used it on my suburban and it worked without any problems. reason was I had already modified my truck frame with air ride stuff and a new cross member so it was easier to swap it than start over. it is on my build thread with pictures.
gostranger is offline   Reply With Quote
Old 08-07-2014, 07:29 AM   #5
chakah
chakah's Avatar
Re: Frame lengths
The wheelbase is the same. Although the back part from the wheel to the rear bumper is slightly longer of about 4" to 6". I can measure it after work later today if you'd like.
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 08-07-2014, 11:18 AM   #6
1963 c10
Re: Frame lengths
Thanks for your reply, Chakah it's all good
No need to measure thanks again.
Old 08-07-2014, 04:18 PM   #7
padresag
Re: Frame lengths
it may also depend upon w/b as here is my 157" w/b 1t. it does appear to kick up higher in the rear.
there is also a difference between the dimensions of the frame rails as show in the following link
http://67-72chevytrucks.com/vboard/s...d.php?t=550856
ron
padresag is offline   Reply With Quote
