Old 08-10-2014, 09:18 PM   #1
SLDPULR
SLDPULR's Avatar
Valve spring question
I have been trying to do as much research on this as I can but I'm lost now. There is so many different options I need a experts help. I bought a comp cams Xtreme energy cam. Specs are duration 294int/306exh rpm 2800-7000 hyd flat tappet, valve lift 519int/523exh. The edelbrock heads I bought were set up for a roller cam and .640 lift. The OD of the springs on the heads are 1.55 and all of the springs I see online are 1.22 OD. Could you guys help me pick out a good set of springs. Thanks
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES)
SLDPULR is offline   Reply With Quote
