Old 08-11-2014, 10:46 PM   #1
56HOTRODDER
electric to mechanical window swap
searched the site but didn't get any results. Is it easier to just swap doors than to get rid of the non working electric windows in my 87 Burb? will p/u doors bolt on? Slow/nonworking windows seem to be a common problem with the 80's Suburbans.
56HOTRODDER is offline   Reply With Quote
Old 08-12-2014, 07:39 AM   #2
tobiahr
tobiahr's Avatar
Re: electric to mechanical window swap
you should be able to swap doors from the same series truck or even blazer. It would be a great deal easier than swapping the internals and finding a new door panel for the manuals
tobiahr is offline   Reply With Quote
Old 08-12-2014, 09:41 AM   #3
Jonboy
Slots go on anything!
No need to swap th ewhole door. Just swap out the regulators out, and you should be good to go. If you are feeling frisky, you can completely pull the wiring and all, but it isn't necessary.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-12-2014, 11:21 PM   #4
Irish1941
Irish1941's Avatar
What Jonboy said. Same same
Bolt in exactly the same spot. Only thing going from power to manual is door panel holes won't work. Power switch is huge compared to manual hole esp on Suburban with their gang 4 switch for windows.
Irish1941 is offline   Reply With Quote
Old 08-13-2014, 08:42 AM   #5
tobiahr
tobiahr's Avatar
It is easier to swap an entire door than to swap the regulators and door panels. 8 exposed bolts to remove the door and you will need to pull the panel on the electric door to unplug the electrical. You will also need to cap off the hole on the body the electrical cable run through or you will get water in the cab when it rains.
Old 08-18-2014, 04:58 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
my 87 burb was manual windows + PL.
they slid right into the 88 burb,replaced the PW no prob
i've now switched out the 78 to using the 87 drivers and 89 pass in the jimmy
lol the round peg fits the square hole,can't even tell
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-19-2014, 08:02 AM   #7
56HOTRODDER
thanks for the help. With no working AC and windows that wont go up and down its a bear to drive in the summer!!!
