Old 08-13-2014, 04:06 PM   #1
chevytrucksforme
1974 Stepside Project
I'm fairly new to this site but just recently started a new project. It's a 1974 Chevy stepside that I pretty much picked up as someone else's basket-case. It appeared to me that someone started the project many years ago then put it in storage. I guess they bailed on the storage bill and that's where I came in to possession.
My plan is to bring it back to it's glory with some more modern upgrades. I have a 1997 Vortec 5.7 that I'm building to put in it for now. I'll probably go with a carb'd version of the vortec but eventually plan to put a LM7 5.3 in it.
Pics coming soon!
chevytrucksforme is offline   Reply With Quote
Old 08-13-2014, 04:59 PM   #2
flashed
Re: 1974 Stepside Project
Im in for some pics .
flashed is offline   Reply With Quote
Old 08-13-2014, 05:14 PM   #3
chevytrucksforme
Here is what it looked like when I picked it up. Parts everywhere! LOL
Not sure why these wheels were with it but I took them and sold them. Made my purchase price even better!
Same with the engine. It was an old SB 283. Sold it too!!
Old 08-13-2014, 05:24 PM   #4
chevytrucksforme
These are pics of me tearing it down and getting parts put away. That's my other project in the background, 1970 Camaro. I'm crazy to have two going at the same time but the truck was too good a deal to pass up.
This is the body cart I made for the cab to sit on. I'm not sure why I didn't take any pics once it was mounted.
Additionally, I took the bed apart and everything is put away. Next step is starting the rust repair. Looks like I've got both rockers to do and part of one floor pan.
Old 08-13-2014, 05:44 PM   #5
midnight rambler
midnight rambler's Avatar
im in
midnight rambler is offline   Reply With Quote
Old 08-13-2014, 06:33 PM   #6
flashed
I like both of your projects and look forward to more updates .I have a 74 stepper too that I rescued from sitting in a barn for over 20 years ,its now my daily driver and a good old truck .Its not very much to look at but I have no plans to restore it as it only has 60,000 miles on it and I need one to use for a truck. Good luck with your builds and please start a build thread on your 70 Camaro in the alternate tinkering section as I would like to follow along with it too.
Old 08-13-2014, 07:29 PM   #7
chevytrucksforme
Originally Posted by midnight rambler View Post
im in
Thanks MR!
Thanks Flashed! Sounds like an awesome find you have there.
Old 08-13-2014, 07:54 PM   #8
rip2174
nice start
rip2174 is offline   Reply With Quote
Old 08-14-2014, 08:16 PM   #9
chevytrucksforme
Originally Posted by rip2174 View Post
nice start
Thanks RIP!
Old 11-25-2014, 07:08 PM   #10
chevytrucksforme
Finally got to get back at my project. At least I got some parts ordered and Santa (FEDEX guy) showed up with some stocking stuffers.
Old 11-25-2014, 07:38 PM   #11
Sodak
Active Member
Sweet love my steppers as well.
Sodak is offline   Reply With Quote
Old 11-25-2014, 09:22 PM   #12
hobbz
hobbz's Avatar
Looks like you are off to a good start
Hobbz-Garage
1987 Short Step 350/350
hobbz is offline   Reply With Quote
Old 11-25-2014, 09:46 PM   #13
flashed
Them's gonna be some mighty big stockings .
Old 01-10-2015, 12:31 AM   #14
85supersierra
85supersierra's Avatar
man you gotta have some great neighbors. neighborhoods around here would be calling the cops on somebody having a stripped truck and mustang in their driveway
85supersierra is offline   Reply With Quote
Old 01-10-2015, 06:35 PM   #15
rusty76
rusty76's Avatar
I'm in for the ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-10-2015, 07:21 PM   #16
stepside83
stepside83's Avatar
looks like a good project im in
stepside83 is offline   Reply With Quote
Old 07-06-2015, 01:27 PM   #17
chevytrucksforme
Hi All,
Well been away for a while. Back in December I injured my back and was out of commission for several months while trying to get healed up. Been doing a little work on the truck even though it's not going as fast as I want.
The original cab ended up having a ton of rot around where the heater core had been leaking for a long time. I decided to pick up another cab that was in better shape on the firewall. It had more rust in the floor and rockers than my original cab but I had planned to replace those anyway. The original cab also had the roof cut for a sunroof so I'm happy to have a cab without the hole.
I'm nearly done with replacing the right side floor pan, inner rocker and outer rocker but I took the holiday weekend to get the frame back in the garage to start wire-wheeling and painting.
Old 07-06-2015, 01:31 PM   #18
chevytrucksforme
A couple pics of the new cab as I was tearing it apart. I did cut the dash off so that I have more room to work while doing the sheet metal repairs.
Old 07-06-2015, 01:36 PM   #19
chevytrucksforme
This was what I started with on the right side.
You can see here that I cut away the outer cowl to make it easier to replace the floor and kick panel. Also have a brace welded across the door opening to help keep things straight.
Old 07-06-2015, 01:40 PM   #20
chevytrucksforme
More cutting away the bad.
You can see here the upright brace I put in place between the body cart and the other door brace. This will keep the A pillar from dropping hopefully while I replace the cab support.
Old 07-06-2015, 01:43 PM   #21
chevytrucksforme
Starting to get some good metal in place. This is after installing the cab support and inner rocker. Test fitting the floor pan.
I cut this piece out of the original cab and tacked in the new cab rather than trying to build something new.
Old 07-06-2015, 05:17 PM   #22
tinydb84
tinydb84's Avatar
Damn that's a lot of work. Are rust free cabs that hard to find over there?
David
Instagram: myfabguy
Old 07-06-2015, 05:31 PM   #23
chevytrucksforme
Hey David, they're not too hard to find. This one cost me almost nothing and I already had most of the replacement pieces. Not to mention, I really need the practice!
Old 07-07-2015, 12:35 PM   #24
stampy
stampy's Avatar
Nice Work! Keep the pics coming, I will be doing the same thing shortly, just picked up my donor cab this past weekend!
stampy is offline   Reply With Quote
Old 07-07-2015, 01:56 PM   #25
chevytrucksforme
Thanks stampy!! Good luck with your build!!
Rick
