08-17-2014, 10:27 PM | #1 |
Adding a parking brake light with factory idiot light
If I put a switch down at the pedal mechanism could I not tie it directly to the brown Brake wire? I mean I don't even need a diode because I don't care about backflow, it's just a switched ground.
This seems like such a good and simple idea but I've never heard of it being done. If wired like this you'd still have your hydraulic warning but you'd get a "you left your parking brake on" light as well (same light).
08-18-2014, 12:25 AM | #2 |
Re: Adding a parking brake light with factory idiot light
I don't see any reason why you couldn't. I think the hardest part would just be mounting the switch.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
08-18-2014, 01:47 AM | #3 |
Hi Dave, I have done this twice and it works good. I think I found it in the under $50 mods thread. Sorry about the pics, (too late to try to fix them)! The link said, "I mounted a brake light switch that is normally open on the parking brake bracket, I grounded one of the two connections to the bracket and ran a wire from the other connection to the brown brake wire on the master cylinder. Now when the key is on and the parking brake is engaged the "brake" light in the dash lights up until I release the parking brake. It was a ten minute operation and works perfectly.
This is the switch with the brake engaged and the switch closed, activating the "Brake" light in the dash. The Brake light on with parking brake on and key in run position. The light goes out when the key is off or in the acc position. Note the splice could be placed anywhere along the (20 TAN 33) wire circuit" |
08-18-2014, 12:38 PM | #4 |
i just got done doing mine this weekend. i used a switch from a 94 chevy truck and it was less than three dollars at oriellys
08-18-2014, 01:35 PM | #5 |
This is a great idea. I have never thought of doing this.
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades. Formerly known as mtndewmaniac66. |
05-28-2023, 12:10 PM | #6 |
Here’s how I did it on my 66, same logic as above though.
http://67-72chevytrucks.com/vboard/s...d.php?t=419932 |
05-28-2023, 12:25 PM | #7 |
If my parking brake is on I don't need a light to tell me. The truck won't move
05-28-2023, 12:33 PM | #8 |
I'm a little surprised Dave wouldn't build a logic circuit to determine if the brake should actually be on and release it automatically if necessary.
The man is a computer genius, for those who didn't know. Check out his YouTube channel.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-28-2023, 12:37 PM | #9 |
Great point kwmech, truck shouldn’t move if the parking brake is on - but this issue usually arises when someone drives without the parking brake “fully” disengaged (or at least that was why I went down this road). Truck will drive fine and folks will wonder why their rear brakes wear so fast or get so hot. This was the case with my 66 anyway, that goofy pre-68 lever didn’t always go all the way back to fully disengaged when released. The little adapted brake switch can be very fine tuned to only extinguish when the parking brake is fully disengaged.
05-28-2023, 01:27 PM | #10 | |
I have been subbed to his channel for a long time.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
05-28-2023, 02:55 PM | #11 |
