08-22-2014, 07:54 PM | #1 |
Water pump wobble and question for Hart Rod and Br3w 6L80E
Hey all,
2011 5.3/6L80 combo. While driving today I noticed a slight vibration under normal driving. It appears about half way through the rev range when doing some easy driving. It almost feels like a break draggin but goes away. This happens in every gear and when cruising I can feel it when slight pedal input is applied, when I let off the pedal it goes away. I checked fluid and it is good, any ideas??? Also, while looking under the hood for this I noticed my water pump and balancer wobble a little, is this normal?? https://www.youtube.com/watch?v=zNye...ature=youtu.be |
08-23-2014, 01:04 AM | #2 |
meowMEOWmeowMEOW
Re: Water pump wobble and question for Hart Rod and Br3w 6L80E
The pulley looks a little wonky, like maybe the pump was dropped at one point or something?
How many miles have you put on the swap Ben? What your describing is sometimes actually caused by cam surge, but that is unlikely to be an "overnight" problem. Its something that would happen after a tune or change in equipment on the existing tune.
08-23-2014, 12:26 PM | #3 |
Hi Br3w, thanks for responding. I probably have 2-3k miles on the swap, odometer not currently working. I guess I might have to bite the bullet and buy hptuners and laptop, not that I know how to use it. As far as the water pump, idk, could have been by the yard it came from. It has t created a problem, just didn't know if it was part of the current problem.
08-23-2014, 01:40 PM | #4 |
Should I not be driving it?
08-23-2014, 02:02 PM | #5 |
Pull the belt and try to move the pulley by hand. If the pulley moves then the bearing in the pump is bad and the pump needs replaced. Water pumps wear out and should be replaced when you swap in the engine. Also make sure to replace the thermostat with one that matches the water pump.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
08-23-2014, 02:27 PM | #6 |
Thanks!
08-24-2014, 04:16 PM | #7 |
Do you have the DOD/AFM disabled in your tune?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-25-2014, 08:29 AM | #8 |
I have no idea Hart rod. I guess I'm going to have to buy HPtuners and see if I can figure anything out, never used it before. Should I be driving with this vibration??
08-25-2014, 01:07 PM | #9 | |
meowMEOWmeowMEOW
...but if there is a problem we haven't diagnosed yet, I don't want you to put serious miles on it an accellerate the wear process. Who did your tune Ben? You should be able to ask them if afm was removed. While buying HPT is awesome, in this case we might be able to get the info from your tuner before going that far.
08-25-2014, 02:27 PM | #10 |
Hi all,
I am going to check the pump tonight when I get home. Last time I drove it (Friday the 22) the temp stayed between 190-195 the whole time in this Houston heat. Sorry, I should have been clear on the second time I asked if it was ok to drive as I was speaking for the cam surge that time. I will ask my tuner to see what he did but out of curiosity, how bad is cam surge? Also, sorry if I should know but I don't, what are DOD/AFM? Thanks for the replies and I will update when I get home. Last edited by Houston Ben; 08-25-2014 at 02:42 PM. |
08-25-2014, 02:54 PM | #11 |
DOD is displacement on demand and AFM is active fuel management. Are you asking how bad is it for the motor?
Typically cam surge wont damage anything. Is this a stock cam motor?
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
08-25-2014, 04:02 PM | #12 |
meowMEOWmeowMEOW
Cam surge is a driveability/performance issue, not really a "problem". Its more common the bigger the cam is, because the ecm wants to bounce back and forth shooting for stoich.
If your going down the road at 35mph giving it 10% throttle, then all of a sudden it feels like you need to give it 20% throttle to go the same 35mph...thats cam surge. If your going 40mph at 20% throttle then randomely it feels like you only need to give it 15% to go the same speed...thats the OTHER side of that cam surge.
08-25-2014, 04:52 PM | #13 |
Ah, got ya, Thanks Br3w!!
Thanks all who have responded, it is much appreciated! |
08-25-2014, 05:45 PM | #14 |
Thanks Boosted!
08-25-2014, 05:52 PM | #15 |
Np Ben. Is your motor stock cammed? Did you take it and have it tuned or just send in an ecm somewhere to have the normal stuff removed?
08-25-2014, 06:05 PM | #16 |
Motor is stock cam and I took it to a person to have stuff removed and tuned. He just got back with me and stated they always turn off the AFM but the dod lifters are weak and tend to fail....I have no idea what that means!! lol.
Thanks again guys! |
08-25-2014, 07:13 PM | #17 |
Ok, he stated DOD is NOT turned off. Said he could turn it off electronicly but I would need to buy a bunch of parts to turn it off mechanically as well.
08-25-2014, 07:28 PM | #18 |
Just checked, water pump and balancer do not move.
08-25-2014, 07:42 PM | #19 |
I bet that's the surge you feel..
08-25-2014, 08:06 PM | #20 |
Just took it for a test drive, seems more noticeable when turning. It still there how ben slowly driving through the gears or when at speed and keeping steady to slight more pressure to pedal...
08-25-2014, 08:12 PM | #21 |
Hart Rod, do I really have to buy some part to turn it off as well?
08-25-2014, 10:36 PM | #22 |
You can turn the AFM off within the tune, just a click of a button. If you were going to change the cam to one with a high lift (.600+) and install dual valve springs, then I would recommend you mechanically delete the AFM, as AFM lifters are a weak point and don't like high lift or RPMs. With stock motor, you should be good with just turning it off in the tune, JMHO.
08-29-2014, 08:07 PM | #23 |
Ok, I figured out the vibrations problem but still stuck with a problem.
I took off the DD a/c bracket and put on the old belt tensioner with serpentine belt and bingo, vibration was gone Problem now is, why does it vibrate with the dd and compressor attached? Anyone have any experience with the DD ac mount on a truck engine?? |
08-31-2014, 09:37 AM | #24 |
Anyone have any ideas? Ac compressor is not hooked up yes so it is just acting like a pully for now.
08-31-2014, 10:15 AM | #25 |
meowMEOWmeowMEOW
Does the pulley on the DD bracket spin ok when off the car? If it had a bearing go out, it would chatter and vibrate a ton.
