Old 09-04-2014, 04:01 PM   #1
1968k10blue
1968k10blue's Avatar
Rocker panel repair
on my new 05, the rockers are still solid but no paint is there any longer. What should I do? clean it up, POR and rhinoline? or just paint it back to factory?
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 09-06-2014, 03:05 PM   #2
vanaman
Re: Rocker panel repair
i would por-15 them and not need to worry any more
vanaman is offline   Reply With Quote
Old 09-21-2014, 10:55 PM   #3
72Thunder
You could por them. If the paint has been all chipped/flaked away and they have some surface rust you could sand the rust to bare metal (if there are any pits, grind them out the best you can), clean it off well with a degreaser, give it a quick shot of an etching primer and a couple coats of paint and clear to match your vehicle. If you'd prefer for extra protection in the future and satisfaction, finish up with some rocker guard and paint to match if you'd like. Just a few suggestions. Goodluck!
72Thunder is offline   Reply With Quote
Old 09-23-2014, 12:43 AM   #4
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
after the paint is on, squirt some oil or atf up in the weep holes to hopefully get in the cavities. they rust from inside out
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
