hey guys! i had a thread titled new here, 69 longbed build. i changed direction shortly after i made it. i bought a short frame with a stepside bed and disc brakes all around. you can find the previous work here. 67-72chevytrucks.com/vboard/showthread.php?t=602406
i will be updating this thread now. next on my list is putting my motor back on, fixing my rocker and cab corner and bed. ill post pictures soon |
Re: 69 short stepside build
started doing some rust repair on my door. im in the process of filling in the mirror holes right now
patched up
peep mirror and mirror holes filled in
heres a quick recap of what ive done to my truck
heres when I first bought it and then when I started tearing it apart.
the stepside at the end is the parts truck I bought. it had front and rear disc brakes. |
I removed the rocker panel and cab corner. I still haven't welded the new ones in. I sandblasted and painted the motor and just recently hooked up all the brake lines
I sandblasted and painted my rear disc brakes but when I tried to put the wheels on the studs aren't long enough. they only get about a quarter inch. does anyone know who makes or have a part number for a longer wheel stud?
i finally dropped my motor in.
i bolted up the transmission this morning. I made a custom transmission mount, all i need is to weld the tabs that hold it up and ill be able to move it outside for a wash
i put in the transmission crossmember and starter.
while i was working on the transmission my dad got to work on the cab corner and rocker panel.
#13 |
he started by brushing on a rust converter from eastwood, after grinding off the rust. then welded the rocker followed by the cab corner
#14 |
motor exploder
Call Moser about the wheel studs - www.moserengineering.com
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#15 | |
#16 |
i got my cpp drop spindles put on last night
#17 |
i cant remember what this line that was hooked up to the transmission went to. anybody got a clue?
#18 |
motor exploder
if the line in your hand runs to that little canister on the passenger side of your transmission, that is your vacuum modulator valve hookup. It should connect to a manifold/unported vacuum source (below the throttle blades) of your carb. You can connect it right on the manifold with an NPT to hose barb adapter or on the baseplate of your carb if you have a corresponding nipple on the baseplate of the carb.
#19 |
I really like the dark blue paint you used on the engine, nice touch.
#20 | |
#21 |
i havent been doing much to my truck lately. been busy with other stuff but i made a drive shaft since my two piece one wasn't going to work. i tested it n it fits good, i just gotta go get it balanced
#22 |
so i put in the new exhaust manifolds today
#23 |
i also cut my exhaust pipes and left them ready to weld tomorrow
#24 |
well i still havent welded the exhaust, been busy doing work around the house but i did paint my engine brackets and fan and put them on
#25 |
Still Learning
Nice looking project mandojunior. I hope to get the chance to see it in person some time. I'm just east of you a bit. Subscribed...
