Old 09-20-2014, 01:14 PM   #1
bL.A.zer90045
86 2wd k5 driveshaft?????HELLLLLLPPPP!!!
looking for a good source to get a driveshaft for my 86 4wd k4 thats been converted to 2wd? im planning on using a th350 temporarily mated to a 454 bbc.ive seen 2 kinds of diveshafts,2-piece,and 1 piece??? please explain the purpose of this? any help/insight/know-how,GREATLY appreciated!!!
bL.A.zer90045 is offline   Reply With Quote
Old 09-20-2014, 01:50 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: 86 2wd k5 driveshaft?????HELLLLLLPPPP!!!
I only know the most basic stuff about them. The two-piece drive-shafts will be found behind a transmission (or transfer case) that has a fixed-yoke output and the one-piece drive shafts will be behind a tranny with a slip-yoke output. The TH350 should have a slip yoke and thus you'd need a one-piece driveshaft. Is that what you meant?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-20-2014, 09:16 PM   #3
bL.A.zer90045
yes sir! coming to my aide once again!!! so could i use one from say a 78-88 g-body(monte,el camino,regal,cutlass,malibu,etc)or do you know if denny'sdriveshaft has custom ones avail? thanks!!!
Old 09-20-2014, 09:33 PM   #4
68Timber
68Timber's Avatar
I don't know but it might. If you'll measure length from the middle of the u-joint bearing cups and the diameter of the drive-shaft, I'll compare it to my 2wd 79 and see how they match up. If they're close we can check the u-joints and see what you'll need. The Blazer wheelbase is actually 1.5" shorter than the 78-88 G body so you might be able to cut it down and use it. Measure and let me know.
John
74 Honda Z50 build
Old 09-21-2014, 07:26 PM   #5
bL.A.zer90045
thats what im talking aboutill get some measurements...
Old 10-01-2014, 08:38 PM   #6
UKNOWME
UKNOWME's Avatar
I took mine to a local driveline shop and they rebuilt it to proper length.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
