Old 09-20-2014, 10:02 PM   #1
twangismythang
twangismythang's Avatar
87 Square Body Build up....
Here begins the build up of my 87 V-10 I scored today for $1600. I bought the truck from my brother, who bought it with hopes of building it but then realized he would rather buy a
$ 50,000 diesel truck.
The 5 mile drive home only took about an hour as I drove, pulled and pushed. Acts like the carb is junk or bad gas or both.
The radiator leaks, the steering column is loose, the engine starts with a toggle switch.
Heres a few pics to get things started.
Real good tires.....
Victory will only be achieved through superior firepower and trusting in the Lord.
SOLD 68 C-10. http://67-72chevytrucks.com/vboard/s...d.php?t=560975
SOLD 2000 Silverado...http://67-72chevytrucks.com/vboard/s...=1#post6492671
87 V-10 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=643898
twangismythang is offline   Reply With Quote
Old 09-20-2014, 10:21 PM   #2
twangismythang
Re: 87 Square Body Build up....
Here is a few I took after giving it a washing...
Had to install my favorite license plate.
So I sent 1 of my buddies a pic of the truck, he showed it to a coworker of his and turns out the guys son use to own the truck. He went further to add when his son bought it the seller told him the engine had a recent rebuild. The then owner had the transmission rebuilt before he sold it and said that the engine probably has less than 7,000 miles on it.
So turns out I have a good engine and trans, the body has no rust and not much damage.
Score for $1600!!!!
I have to first figure out the fuel delivery situation as well as the cooling system. I will also have to rebuild the steering column.
That will be just to get it going, then who knows whats next.
However first things first, I simply wanted a clean 4X4 to tool around in, I have little desire to play in the mud, although I might. With that being said the first thing I will do is ditch the roll bar. I will remove it in the morning and hopefully sell it to buy a tool box for the bed or I dunno a RADIATOR.
Probably going to try and eventually find some steel wheels and caps and just run some over sized all terrains.
So that's the plan a semi stock looking 4X4, we shall see how well this one goes....
Old 09-20-2014, 10:32 PM   #3
Just call me Sean
Just call me Sean's Avatar
That should be fuel injected.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 09-20-2014, 10:42 PM   #4
twangismythang
Yep shoulda been, but its got a edelbrock carb and a bunch of hacked up wiring.
Old 09-21-2014, 08:43 AM   #5
CHROMAHOLIC
CHROMAHOLIC's Avatar
that plate rocks
CHROMAHOLIC is offline   Reply With Quote
Old 09-21-2014, 01:15 PM   #6
Just call me Sean
Doesn't surprise me.
Old 09-21-2014, 09:13 PM   #7
twangismythang
Today I accomplished removing the roll bars, ran into some level of difficulty with the dual gas tanks and had to grind one of the bolt heads off.
Leaner and Sexier........
Going to try and find a buyer, or trade it for a bed tool box.
Notice that either the beds crooked or the frames bent, anyone have any ideas on how I can tell? Looks more like the frame since the bumper turns up with the bed on the right side.
Old 09-21-2014, 09:22 PM   #8
twangismythang
Here are some other pics of the foolishness that has taken place by the PO's.
wires everywhere
was going to hang my old school rifle rack in the back window but didnt have the screws to hang it, it will have to wait for another day.
Here is a shot of the carb, its very juvenile in appearance. I just need to find a donor TBI truck and change it back to TBI.
Old 09-21-2014, 10:14 PM   #9
Just call me Sean
Looks like the motor was changed. Doesn't have '87up heads.
Old 09-21-2014, 10:44 PM   #10
twangismythang
I'm thinking its an older block, will have to climb up and read the numbers.
Started up today with no issues and idled fine in the driveway, didn't feel like any drama so I didn't attempt taking my buddy for a test drive. Going to drop the gas tank soon and start replacing and cleaning from there...
Old 09-24-2014, 08:47 PM   #11
twangismythang
Tackled the loose steering column today, found that it does not appear to be the original column. I am unable to find a switch to turn the wipers on, I am thinking the 87 had the wiper control built into the turn signal arm?
So now I have replaced the ignition key switch and replaced the juvenile steering wheel with one I had lying around.
While I was at it I changed out the door lock cylinders, so now at least I am able to secure the truck. That was really bothering me because the truck came with no keys.
Here's a few pics of the progress.......
now the new wheel....it will do for now
Gonna have to buy the horn kit if I'm gonna keep the wheel on it.
Old 09-24-2014, 08:54 PM   #12
Just call me Sean
Yes the wipers are supposed to be on the turn signal lever.
Old 09-24-2014, 09:25 PM   #13
twangismythang
Guess I will have to hit the junk yards sometime soon.
Old 09-29-2014, 10:03 AM   #14
twangismythang
Since we are trying to sell our house the wife made me hide the truck in the backyard.
Looks good there 2
Minor update, hung the rife rack I have had put away for some years. Small accomplishment, but I'm happy with it.
Old 09-30-2014, 08:33 PM   #15
twangismythang
The primer job wasn't all that great so I had the bright idea of wet sanding it off and just spot priming the bare spots. I didn't take into account that the doors were a different color than the rest of the truck.
I was just trying to do something that didn't cost any money, not sure if I like the new look or not.
Old 10-06-2014, 08:50 PM   #16
twangismythang
No real progress, I have been too busy prepping my house for sale. I did find out that it fits in the garage with 4 inch lift and 33's.
Also found that these tires cost about $230 a piece, pretty cool since the truck only cost me $1,600.
A few more of some seasonal stuff
Have to figure out how to decode this and find out what I actually have.
Looks like its a Silverado?
Old 10-08-2014, 02:24 PM   #17
twangismythang
When you start the engine it throws sparks off of the positive cable on the battery, appears that the alternator is grounded, however these connectors don't look so good.
The heater core was leaking and the PO began tearing into the replacement job only to loose a bunch of parts. I went ahead and went in behind the fender to get the last bolt out.
Found this behind the dash, think it goes to what once was power windows and locks, any ideas?
Old 10-08-2014, 02:49 PM   #18
Just call me Sean
They sell that connector at AutoZone.
Old 10-08-2014, 03:35 PM   #19
twangismythang
Great I will pick one up next time I'm there….
Old 10-12-2014, 01:23 PM   #20
JGood
JGood's Avatar
Love that steering wheel! Got an identical one in my 86 and a matching shifter as well!
1986 Chevy Silverado LWB (project)
1967 Chevy SBSS (future project)
2003 Chevy Tahoe (wifes daily)
2004 GMC 2500 Duramax (company truck)
1986 GMC Wrangler LWB (newly acquired beater)
JGood is offline   Reply With Quote
Old 12-03-2014, 10:45 PM   #21
twangismythang
Christmas came a lil early for me, decided to spend some money, swapped out the single plane intake for a dual and got it running a lil bit better. Figured I would tune it up and see if it will run.
Also scored a free steering column to have wipers.
Old 12-03-2014, 10:58 PM   #22
twangismythang
My daily driver rocks!
Old 12-03-2014, 11:15 PM   #23
Just call me Sean
Oh **** it's the cops.
Old 12-04-2014, 10:56 AM   #24
Katrina/10
Katrina/10's Avatar
Are you still thinking of putting TBI back on?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 12-04-2014, 05:33 PM   #25
83swb
Love the truck and the stance, shame the wiring is so hacked.
I have to tackle the loose column in my project, it was in a front end collison and looks like the driver may have hit the steering wheel, hoping there aren't any mangled internals.
83swb is offline   Reply With Quote
