Old 09-22-2014, 11:11 AM   #1
vjjack04
vjjack04's Avatar
hard 1-2 shift fix
I have a 2006 GMC and just today the transmisison started shifting really hard from 1st to 2nd gear. Check engine light is also on. The truck is a 2006 GMC Sierra 4 wheel drive with a 5.3 liter V8. Any ideas?
vjjack04 is offline   Reply With Quote
Old 09-22-2014, 09:22 PM   #2
Old Money
Re: hard 1-2 shift fix
yes i had that same problem in 05 gmc k1500. valve body in transmisson is culprit. take it to a transmission shop. google problem. it cost me 300 dollars, fluid, filter,and parts and labor. old money.
Old Money is offline   Reply With Quote
Old 09-25-2014, 10:36 PM   #3
clinebarger
What Codes are set?
clinebarger is offline   Reply With Quote
Old 09-26-2014, 08:43 AM   #4
Old Money
1870 i think, trans.componet slipping.
Old 09-26-2014, 08:35 PM   #5
clinebarger
The Infamous P1870, That will cause a harsh 1-2 shift.
The most common cause is the Isolation-PWM Converter Valve has worn the Bore that it rides in.
The Actuator Feed Limit Bore wears as well, The controls pressure to the ISO-PWM Conv. Valve.
Sonnax makes fixes for both, Requires the Valve Body to be reamed for oversized valves. The Tool kit for both bores are around $800, So its not something a DIY'er wants to pay entry price for.
VBX is owned by Sonnax & will have all the updates, http://valvebodyxpress.com/prodView.php?theId=65
